VEXcode VR Enhanced and VEXcode VR Premium include access to offline versions of VEXcode VR for locations with intermittent or no internet access.
This article provides step-by-step instructions for sharing and using Offline VEXcode VR, including how and when to verify licensing information.
Download Offline VEXcode VR
Go to the VR Admin System, located at vradmin.vex.com.
Note: If you're not logged into your VEX account, you'll be prompted to sign in.
Offline mode highlighted in VEXcode VR
Select Offline from the navigation bar on the left.
Offline VEXcode VR launch screen with options to create a new project or open an existing project
Select the appropriate download button for your operating system.
Go here for instructions on how to install VEXcode VR on Windows.
Go here for instructions on how to install VEXcode VR on macOS.
The download link can be shared with students and families for use in combination with your class code.
Entering a Class Code for Offline VEXcode VR
The prompt reads Welcome to VEXcode VR! A valid Class Code is required to use VEXcode VR Offline. Please login with your VR Class Code, with a text box to enter the class code and a submit button.
When offline VEXcode VR is launched, the user will immediately be prompted to enter the class code. To learn how share a class code or to log into a class in VEXcode VR Enhanced or Premium, see this article.
Verifying Class Code Eligibility
Offline VEXcode VR requires a class code and internet connectivity to validate the license at the first use. After the first use, VEXcode VR offline clients will need to connect to the internet to verify class code eligibility at least every 30 days.
Saving VEXcode Projects
Once you have downloaded and installed Offline VEXcode VR to your device, projects can be saved using the file menu.
Windows
File menu in VEXcode VR with Save highlighted and labeled Ctrl+S
Open the File menu and select Save or Save As.
VEXcode VR launch screen with the Open in App option for offline use
A dialog box will show. Navigate to where you want to save your VEXcode project and select Save.
Offline VEXcode VR launch screen with options to start coding or open a project
Your file will be saved in the chosen location.
macOS
VEXcode VR workspace open in offline mode in a web browser
Offline VEXcode VR interface with the Playground and coding workspace open in a browser
Select where you want to save your project and then select Save.
VEXcode VR interface opened in offline mode
