Activating a VEXcode VR Enhanced or Premium License
After you have purchased a license, you will receive access to many exciting features, including additional playgrounds, the ability to create a class in VEXcode VR, and more.
This article will walk you through the steps to activate your VEXcode VR Enhanced or Premium license key so you can get started using all the features of VEXcode VR Enhanced or Premium.
Note: If you have not yet purchased your license, it can be purchased at this link.
Activate Your License
After you have purchased a license, you will receive an email from VEX Robotics with your license key.
Next, go to login.vex.com and login using your VEX account.
Don’t have a VEX Account? Fill out this form to register for a VEX Account.
Select 'License Keys' from the menu on the left.
Input your license key that you received by email, select the checkbox to agree to the terms of use, and select 'Activate.'
You will see a green banner at the top of the screen letting you know that your license key has been successfully activated.
You will also see at the bottom of the screen which platform the license is activated for, the date it was activated, and what day it will expire.
Next, go to vradmin.vex.com and select “Login with VEX Account.”
Once logged in, you will see the Home screen of the VEXcode VR Licensing System.
To access your VEXcode VR Enhanced or Premium benefits, you will need to log into VEXcode VR using a Class Code. See this article to learn how to view your Class Codes and create classes.
  • To learn how to use VEXcode VR Enhanced or Premium offline, see this article.
