Creating Classes in the VEXcode VR Licensing System
The VEXcode VR Licensing System enables you to create and manage classes in VEXcode VR Enhanced or Premium. Each class that is created will have a unique Class Code, as well as the option to set up project sharing preferences. This article will explain how to view and create classes in the VEXcode VR Licensing System.
Note: You will need to activate your VEXcode VR license key in order to use the VEXcode VR Licensing System. If you have not yet activated your license key, see this article to learn how to do so. If you have not yet purchased your license, it can be purchased at this link.
View Your Classes
VR Admin Dashboard reads Home at the top and shows a menu on the left and profile information in the center.
Navigate to vradmin.vex.com and log in.
The Menu on the left in the VR Admin dashboard with the Classes option highlighted, below Home.
Select 'Classes' from the menu on the left side of the screen.
The Classes section of VR Admin with one tile showing a Class named My Class with a 6 digit copyable Class Code beneath it.
You will automatically have one class already created, with a Class Code.
To learn about sharing and using this Class Code with your students, see this article.
To learn about setting up sharing preferences for a class, see this article.
Renaming a Class
A close up of the Class tile with the pencil icon in the upper right corner beside My Class highlighted.
To rename your class, select the pencil icon, as shown here.
The Edit Classroom dialog box with the Class Name section highlighted. The new class name reads Period 1.
Enter your desired class name in the 'Edit Classroom' window.
The same Edit Classroom dialog with the Save Changes button on the lower right corner highlighted.
Select 'Save changes' to save your class name.
The Classes section again, with the name of the class on the tile reading Period 1, highlighted.
Your class will now display the new name.
Creating an Additional Class
The Classes section of VR Admin, with the Create Class button in the upper right corner opposite the Classes header highlighted.
You can add additional classes in the VEXcode VR Licensing System. Select 'Create Class' as shown here.
The Create Classroom dialog box with the Class Name input highlighted. A text box reads Enter class name, indicating where to type your desired name.
Enter your desired name for the class in the 'Create Classroom' window. Note: For information on setting up sharing preferences and changing the delivery method, see this article.
The same dialog with the Class Name reading Period 2 and the Save changes button in the lower right corner highlighted.
Select 'Save changes' to save your new class.
The Classes section of the VR Admin dashboard now showing two class tiles - one labeled Period 1 and on Period 2, with two individual class codes.
The new class will now appear. Note: For information on sharing class codes with your students, see this article.
