Sharing Files in VEXcode VR Enhanced or Premium
VEXcode VR Enhanced and Premium allow your students to share their projects directly with you in Google Drive or Dropbox, or download their work to their local device.
No student data or projects are ever saved or stored by VEX, and VEXcode VR projects do not ever live on a VEX server. Student projects only exist on the local device and the sharing site.
This article will walk you through the steps to configure sharing methods for a class, and the steps students will use to share their VEXcode VR projects with you.
Configuring Sharing Methods
VEXcode VR licensing page showing Enhanced and Premium access options for users and organizations
Navigate to vradmin.vex.com and log in.
Sharing tab with options to manage licenses and share VEXcode VR projects
Select 'Sharing' to connect popular file sharing services to your VEX account.
Authorize Sharing Through Google Drive
Google sharing options for a VEXcode VR project file with access permissions settings
To configure sharing of student projects in Google Drive, select 'Sign in with Google.'
Google authorization prompt requesting permission to share a VEXcode VR project file
Choose a Google account to connect with VEXcode VR Enhanced or VEXcode VR Premium, and review the required permissions.
Select 'Allow' to continue. Google Drive will be marked as 'Authorized!' on the Sharing tab.
Note: Selecting 'Revoke Access' will disable the connection.
Authorize Sharing Through Dropbox
Dropbox option for sharing a VEXcode VR project file
To configure sharing of student projects in Dropbox, select 'Sign in with Dropbox.' Sign into Dropbox to connect it with VEXcode VR Enhanced or VEXcode VR Premium, and review the required permissions.
Dropbox authorization prompt to connect VEXcode VR to your Dropbox account
Follow the prompts provided by Dropbox to finalize the connection. It will ask if you want to authorize permissions for the VEXcode VR Licensing System. Dropbox will be marked as 'Authorized!' on the Sharing tab.
Specify a Sharing Method for a Class
Classes tab showing VEXcode VR license options for Enhanced and Premium access
Select 'Classes' to locate a class and specify a sharing method. To learn how to create a class in VEXcode VR Enhanced or Premium, see this article.
Share button in VEXcode VR for sending a project link
By default, the delivery method for shared projects in a class is 'Local Download.'
'Local Download' will allow students to download their VEXcode VR projects directly to their device.
To change the delivery method, first select the pencil icon in the top right corner of the class block.
VEXcode VR menu showing delivery method options for sharing a project file
Then select the Delivery Method dropdown to view a list of configured file sharing methods.
Note: Sharing options MUST be configured in the Sharing tab before they become available in the drop down for Delivery Method.
Select the desired Delivery Method.
Share button in VEXcode VR for sending a project to another user
Select 'Save changes' to confirm the new delivery method for the class.
VEXcode VR Share button used to share a project file
The class block will reflect the new delivery method and path.
Sharing a VEXcode VR Project
To create and share projects with you through Google Drive or Dropbox, a student must first be logged into VEXcode VR Enhanced or VEXcode VR Premium using your class code. To learn how to log into a class in VEXcode VR Enhanced or Premium, see this article.
Share button in VEXcode VR for sending a project link or copying the project to another team member
Select 'Share' in the top right corner of VEXcode VR.
Project sharing menu in VEXcode VR with options to invite collaborators and manage access settings
Students can enter a name, assignment, and optional notes, then select 'Share.'
Note: Selecting 'Download' will save a copy of the project details to the student's local device.
A popup window will notify you when a project was shared successfully. Select 'Continue' to return to VEXcode VR.
The project file can be found in the location assigned to the class (Google Drive or Dropbox).
Shared projects in Dropbox or Google Drive
Share button in VEXcode VR File menu
When a project is shared with you via Dropbox, you will find it in the directory Apps/VEXcode VR, then sorted into a folder by class, as shown here.
Each project will share two files – a VEXcode VR project (.vrblocks or .vrpython) that you can open in VEXcode VR and run, and a PDF of the project.
Note: In this example, 'My Class' is the name of the Class in VEXcode VR.
VEXcode VR Share button used to send a project to another user in Enhanced or Premium.
Shared projects in Google Drive
When a project is shared with you via Google Drive, you will find it in the VEXcode VR folder, then sorted into a folder by class, as shown here.
Note: In this example, 'Period 5' is the name of the Class in VEXcode VR.
VEXcode VR Share button for sending a project to another user
In addition to the project file (a .vrblocks or .vrpython file) that can be opened and run in VEXcode VR, you will also receive a PDF of the project.
The first page contains students' names and identifying information, along with any notes they submit. It will also show an image of the Playground when the project was stopped, so you can view the result of the project on the Playground, as shown in this example.
VEXcode VR file sharing options for Enhanced and Premium users, including how to share projects with students or other educators
The remaining pages will show a print out of the project, including any notes included in the project.
