Activating a VEXcode VR Enhanced or Premium License
After you have purchased a license, you will receive access to many exciting features, including additional playgrounds, the ability to create a class in VEXcode VR, and more.
This article will walk you through the steps to activate your VEXcode VR Enhanced or Premium license key so you can get started using all the features of VEXcode VR Enhanced or Premium.
Note: If you have not yet purchased your license, it can be purchased at this link.
Activate Your License
An envelope email icon
After you have purchased a license, you will receive an email from VEX Robotics with your license key.
A screenshot of login.vex.com reads Login to an existing account at the top and has text boxes for Email and Password above a Login button in the lower left.
Next, go to login.vex.com and login using your VEX account.
Don’t have a VEX Account? Fill out this form to register for a VEX Account.
The Welcome screen with the License Keys option selected from the menu on the lefthand side, below Account Information. To the right is a space to Activate a license key.
Select 'License Keys' from the menu on the left.
The same screenshot with the Activate a license key section highlighted. A text box to input your license key is at the top, with a checkbox for agreeing to terms of use directly below it. A button reads Activate in the lower left, above the memberships section.
Input your license key that you received by email, select the checkbox to agree to the terms of use, and select 'Activate.'
The same image as the one previously, now with a green banner reading Your license key has been successfully activated at the top, and the Memberships section at the bottom showing a VEXcode VR Premium and activation and expiration dates.
You will see a green banner at the top of the screen letting you know that your license key has been successfully activated.
You will also see at the bottom of the screen which platform the license is activated for, the date it was activated, and what day it will expire.
The VEXcode VR licensing page with the Login with VEX Account button highlighted.
Next, go to vradmin.vex.com and select “Login with VEX Account.”
VR Admin dashboard reads Home at the top, shows a menu on the left and profile information in the center.
Once logged in, you will see the Home screen of the VEXcode VR Licensing System.
To access your VEXcode VR Enhanced or Premium benefits, you will need to log into VEXcode VR using a Class Code. See this article to learn how to view your Class Codes and create classes.
