Installing VEXcode VR on Windows
VEXcode VR is available offline only for users with an active VEXcode VR Enhanced or VEXcode VR Premium license. To learn how to activate your VEXcode VR Enhanced or VEXcode VR Premium license, go here.
Download the Installer
VEXcode VR Setup window with Install button for Windows installation
Go to the VR Admin System, located at vradmin.vex.com.
Note: If you're not logged into your VEX account, you'll be prompted to sign in.
VEXcode VR installer with the Offline option selected
Select Offline from the navigation bar on the left.
Choose VEXcode VR 4.0 in the installer.
Select the Download for Windows button.
Install VEXcode VR
VEXcode VR shortcut on the Windows desktop
Select the VEXcode VR Installer icon to begin installation.
VEXcode VR Setup license agreement with I Agree selected to continue installation.
The End User License Agreement will appear. Once you have read through the EULA, select Agree.
VEXcode VR Setup with Current User selected and Install highlighted
Choose whether it will be installed only for the current user, or for all users on the computer. Once chosen, select Install.
VEXcode VR installation complete with Finish button selected
Wait for the installation to complete, then select Finish.
Launch VEXcode VR using the desktop shortcut.
Log In with Your Class Code
Windows Security prompt asking to allow VEXcode VR to make changes to the device
On first launching VEXcode VR, you'll be asked to enter your VR Class Code. Type the code in and select Submit.
To learn how to create Class Codes for your VEXcode VR classes, go here.
VEXcode VR workspace showing a sample project with When Started and Drivetrain blocks
Begin working in VEXcode VR.
Create a new project to get started with coding in VEXcode VR!
