Accessing Help in a VEXcode VR Blocks Project
Help menu opened from the question mark button in VEXcode VR Blocks
Help explains what a block does so that you can figure out if it’s helpful for your project.
Select the Help icon. It’s at the top right of the interface and has a question mark in it.
VEXcode VR Help panel with block descriptions and usage instructions
You will see a blank screen extend from the right until you select a block to learn about.
Help panel with block descriptions and coding guidance for a VEXcode VR Blocks project
Select any blocks that you want to learn more about.
Help panel close button in VEXcode VR
Hide the Help menu when finished by pressing the right arrow next to the Help icon.
