Creating Classes in the VEXcode VR Licensing System
The VEXcode VR Licensing System enables you to create and manage classes in VEXcode VR Enhanced or Premium. Each class that is created will have a unique Class Code, as well as the option to set up project sharing preferences. This article will explain how to view and create classes in the VEXcode VR Licensing System.
Note: You will need to activate your VEXcode VR license key in order to use the VEXcode VR Licensing System. If you have not yet activated your license key, see this article to learn how to do so. If you have not yet purchased your license, it can be purchased at this link.
View Your Classes
VEXcode VR licensing dashboard showing class management and user license options
Navigate to vradmin.vex.com and log in.
VEXcode VR licensing dashboard showing class management options and license information
Select 'Classes' from the menu on the left side of the screen.
VEXcode VR Licensing System dashboard with license and user account management options
You will automatically have one class already created, with a Class Code.
To learn about sharing and using this Class Code with your students, see this article.
To learn about setting up sharing preferences for a class, see this article.
Renaming a Class
Rename class icon
To rename your class, select the pencil icon, as shown here.
VEXcode VR Licensing System dashboard showing class management options for creating a class
Enter your desired class name in the 'Edit Classroom' window.
VEXcode VR Licensing System page showing class management options for creating and organizing classes
Select 'Save changes' to save your class name.
VEXcode VR Licensing System page showing class management options for creating a class
Your class will now display the new name.
Creating an Additional Class
VEXcode VR Licensing System dashboard with options to manage classes, licenses, and user access
You can add additional classes in the VEXcode VR Licensing System. Select 'Create Class' as shown here.
VEXcode VR Licensing System dashboard showing license management and user access options
Enter your desired name for the class in the 'Create Classroom' window.
Note: For information on setting up sharing preferences and changing the delivery method, see this article.
VEXcode VR Licensing System page showing class management options for adding and organizing classes
Select 'Save changes' to save your new class.
VEXcode VR licensing dashboard showing available licenses and class management options
The new class will now appear.
Note: For information on sharing class codes with your students, see this article.
