Logging Into a Class in VEXcode VR Enhanced or Premium
Once you have accessed your VEXcode VR Enhanced or Premium account and created one or more classes, your students will be able to log in and create projects, use playgrounds, and share their work with you. If you have not already activated your VEXcode VR Enhanced or Premium license, follow the steps in this article to do so.
This article will walk you through how to share your Class Code with your students, so that they can enter it into VEXcode VR to log into VEXcode VR Enhanced or Premium.
Sharing a VEXcode VR Class Code
VEXcode VR Licensing System page with Sign In and Enter Class Code options
First, navigate to vradmin.vex.com and log in.
VEXcode VR login screen showing class sign-in options for Enhanced or Premium access
Select 'Classes' to locate a class and identify its class code.
Sharing a Class Code via Direct Link
VEXcode VR login screen with fields for class number and student name
Select 'Copy Direct Link' to copy a direct link for your class. The direct link can be shared with students via email or other methods.
A direct link automatically embeds the class code so students do not need to input a Class Code in VEXcode VR.
VEXcode VR sign-in screen with class login options for Enhanced or Premium access
You can also share only the Class Code (without the link) for students to enter directly into VEXcode VR.
Select the 'Copy' icon to the right of the Class Code, and paste the code to your desired location. Students will need to navigate to vr.vex.com and enter the Class Code.
Logging into VEXcode VR Enhanced or Premium with a Class Code
Once you have shared your Class Code with students, they will use it to log into VEXcode VR Enhanced or Premium.
Students can log into a VEXcode VR Enhanced or Premium Class in three ways:
  • Via a Direct Link with the Class Code
  • Via Splash Screen login
  • Via the File Menu in VEXcode VR.
Logging in via Direct Link
VEXcode VR licensing screen showing available class login options and license status
Select the direct link that was shared, to be automatically directed to your VEXcode VR Enhanced or Premium class.
Note: Your direct link may look different than the one shown here. Be sure that students use the link that you shared with them, not the link in this image.
Logging in via Splash Screen
VEXcode VR login screen with Class Login and Sign In options
Navigate to vr.vex.com, and select 'Login Here' on the Splash Screen.
Enter your class code in the space provided, as indicated in this image.
VEXcode VR class login screen with fields for class number and student name
Once a complete Class Code has been entered, select the 'Submit' button. The 'Submit' button will not be able to be selected until a complete Class Code has been entered.
Be sure that students use the Class Code that you shared with them, not the code in this image.
VEXcode VR licensing comparison showing Free, Enhanced, and Premium features for class access
The background color of the VR icon in the upper left corner will indicate whether you are logged in to VEXcode VR Free (white), VR Enhanced (silver), or VR Premium (gold).
VEXcode VR will remember the last class code entered until the user logs out.
Logging in via the File Menu in VEXcode VR
The File Menu open in VEXcode VR, in the upper left corner of the Toolbar, with the Login with Code option highlighted.
In VEXcode VR, select 'File' to open the File Menu. Then select 'Login with Code'.
Checking Your Class Code
To check which class you are logged into, select the project name box in the center of the VEXcode VR menu.
VEXcode VR licensing page showing available class login options and license details
The class name and code will be displayed below the project name.
Logging Out of A Class
VEXcode VR license page showing available class login options for Enhanced or Premium access
Select 'File' and 'Logout'. In order to change Class Codes, you will need to log out, then follow the steps to log in via the File Menu in VEXcode VR.
When you are logged out of a class, the Class Code information will no longer be displayed when the project name box in the Toolbar is selected.
  • To learn about sharing projects in VEXcode VR Enhanced or Premium, see this article.
  • To learn how to use VEXcode VR Enhanced or Premium offline, see this article.
