When connecting a VEX AIM Coding Robot to Web-based VEXcode AIM, several potential causes may prevent a proper connection. Read the following article for potential solutions and guides for connecting to Web-based VEXcode AIM.
Connecting to a Robot and Updating Firmware
Connecting
For more information about connecting a robot to Web-based VEXcode AIM, select the article that aligns with your device:
- Connecting VEX AIM to VEXcode AIM - Wireless
- Connecting VEX AIM to VEXcode AIM - USB
- Connecting VEX AIM to VEXcode AIM - Tablet
Updating Firmware
For more information about updating a robot's firmware using Web-based VEXcode AIM, view the following article:
Device Window Not Appearing
The Device Window may not appear if USB devices or Serial port permissions are blocked or disabled. These steps will show you how to enable such permissions.
Open the permissions panel for codeaim.vex.com
Select Site ettings.
Scroll down and ensure both USB devices and Serial ports are not set to Blocked.
Return to codeaim.vex.com. Select Reload.
The Device Window will now appear.
