To start coding with the VEX AIM Coding Robot, you’ll first need to connect it to VEXcode AIM. On tablets, the robot can only be connected via Bluetooth. Follow the steps below to connect the robot.
Connect to a Robot
Turn on the robot by pressing the power button on the back of the robot.
Open VEXcode AIM.
Select the Robot icon in the top right corner.
Select Connect via Bluetooth from the menu.
A window will open showing the available robots. Select your robot.
Then, select Connect.
If this is the first time you have connected the robot to this device, a pop-up will appear in VEXcode AIM. This will prompt you to input a code on your robot's screen.
The 4-digit code will appear on the screen of the robot. Note that this will be specific to your robot. The image shown here is an example of a 4-digit code.
Input the code into the dialog box.
Select Submit.
The Robot icon in the top left corner will now appear green. Now when the Robot icon is selected, the Bluetooth Connection option will read Connected.
The Bluetooth icon on the robot's screen will also turn green to show Bluetooth is connected.
If you see a firmware out-of-date message after connecting, you'll need to connect the robot to your computer using a USB cable. For instructions, see Connecting a VEX AIM Coding Robot to VEXcode AIM – USB.
