Accessing Virtual Skills with a VR Class Code
Educators with a Premium VEXcode VR License can provide students access to Virtual Skills for both VEX IQ and VEX V5 Robotics Competitions using a VR Class Code instead of a team's Virtual Skills Key. This article explains how to use your VR Class Code to access both Virtual Autonomous Coding Skills and Virtual Driving Skills.
Students will need access to their VR Class Code in order to access VR Skills. The same VR Class Code can be used by every student in the class.
Note: Only VR Class Codes from a VR Premium licensed account provide access to Virtual Skills. VR Class Codes from Enhanced licensed accounts will not work for this purpose.
Accessing Virtual Autonomous Coding Skills
Accessing VR Skills in VEXcode VR follows the same process for both VEX IQ and VEX V5.
The Welcome to VEXcode VR prompt with a Have a VR Class Code? Login Here prompt at the bottom of the window highlighted.
Navigate to vr.vex.com, and select Login Here on the splash screen.
The Login prompt with a text box to enter your class code or team number.
Enter your VR Class Code when prompted.
The Login prompt with a VR Class Code entered in the text box and the Submit button highlighted.
Select Submit once you have entered your VR Class Code.
Once logged in, you will be able to access the Virtual Skills Playgrounds to begin coding the Hero Bot!
Accessing Virtual Driving Skills
Accessing Virtual Driving Skills follows the same process for both VEX IQ and VEX V5. VEX V5 is shown here for reference.
The vrskills.vex.com homepage with a VEX IQ image on the left and a VEX V5 game image on the right. Beneath each is a button for that platform's Virtual Driving Skills Practice in the lower right corner, both of which are highlighted.
Navigate to vrskills.vex.com in a Chrome browser. Select the game you wish to practice – VEX IQ or VEX V5.
The Virtual Driving Skills Practice window with the Login to Driving Skills Practice prompt requesting a Team Number and Virtual Skills Key.
Once Virtual Driving Skills Practice opens, you will be prompted to log in.
The Login to Driving Skills Practice screen with the Have a VEXcode VR Class Code instead? button highlighted.
Select the Have a VEXcode VR Class Code instead? button.
The Login to Driving Skills Practice screen with the VR Class Code text box highlighted.
Enter your VR Class Code in the space provided.
The Login to Driving Skills Practice screen with the Login button beneath the VR Class Code text box highlighted.
Select the Login button.
