The VEX AIM Classroom Bundle comes with everything you need to begin teaching with VEX AIM in your setting. Understanding what components are included in a bundle, and how they are packed in the storage bags is helpful as you get started. This article will provide an overview of the contents in a Classroom Bundle, that can be used as reference in your classroom.
This article describes each piece in the VEX AIM Classroom Bundle, organized by its location within the bag, and provides the following information in a table form, from left to right:
- Part: This is the name of the part. Use this for reference when working with VEX AIM.
- Photo: This is an image of the part. Use this for reference while taking out and putting away materials in the classroom.
- Quantity: This is the quantity of each part provided. Use this to ensure you have the correct number of parts in each location.
- Purpose: This column provides information about how the part or parts in that section can be used with the robot or in the curricular resources.
Location: This is an image of the section of the bag or box where the part can be found. This information can be useful when unboxing or repacking into the bundle bag.
- Some parts are found beneath others in the Bundle. Notes will be included to explain where certain items are located.
- Select the image to enlarge.
AIM Kit
Each VEX AIM Coding Robot comes in its own plastic storage case, as a Kit. There are six total AIM Kits in each bundle. This section gives an overview of what is included in each Kit storage case. Note that the cases have a molded plastic insert to keep all components organized.
| Part | Photo | Quantity | Purpose | Location |
| VEX AIM Coding Robot | 1 | Used to carry out VEX AIM activities and challenges. | ||
| One Stick Controller | 1 | Used to remote control drive the robot. |
| Sports Balls | 2 | Objects that can be manipulated by the robot's kicker. | ||
| Barrels |
3 blue 3 orange |
| AprilTag Signs (IDs 0-4) | 1 of each ID (5 total) | Used as location markers with the robot's AI Vision. | ||
| USB Cable (A-C) 1m | 1 | For connecting the robot to a computer. Also used to charge the robot and controller. |
Note: The USB Cable is behind the AprilTag IDs and in a cutout of the plastic Kit liner. |
In the Bundle Bag
In addition to the AIM Kits stacked in the bag, additional bundle materials are packed for easy storage and transportation.
| Field Tiles | 12 | Surfaces for the robot to move on. One Field consists of 4 Tiles. |
| Field Walls | 24 | Creates a barrier around the edge of an AIM Field. One Field has 8 Walls around the perimeter. |
| Parts Poster | 1 | Classroom resource to show the pieces in a Kit and all available emojis. |
| USB Charging Hub (4-Port, 48W) | 2 | Used to charge multiple robots or controllers at once. |
Note: Located in the zippered compartment on the bag's lid. |
| Additional USB Cables (A-C) 1m | 6 | Additional cables to connect and charge robots and controllers. |
| Accessories Bag | 1 zipper pouch |
To replace object or maintain robots as needed. The pouch contains: 8 sports balls; 3 blue and 3 orange barrels; AprilTag IDs 0-4; 2 Allen wrenches |
| Allen wrenches | 2 |
To remove the wheels on the robot if needed. View this article to learn more. | In the Accessories Bag with the spare objects. |
Next Steps with your Bundle
Once you have your materials, and know where and how they are packed into the bundle bag, you can get your VEX AIM Kits ready for student use.
- Label your kits. It is recommended to label each robot, controller, and Kit box so that they can stay together for ease of use and organization in your setting.
- Charge your robots and controllers.
- Access VEXcode AIM and update your firmware. Having up to date firmware ensures that the robot performs as expected.
- Learn more about teaching with VEX AIM in your setting. Visit TeachAIM.vex.com to learn more about curricular resources, teacher support, VEX Professional Development Plus (PD+) and more.
