AIR Educators Start Here
Welcome to TeachAIR.vex.com!
Before joining VEX, I worked in aviation museums across the United States. There, I saw firsthand how the power of flight inspires curiosity and innovation. Drones are a modern extension of that same story. Drone are shaping industries, creating new career opportunities, and showing students what’s possible in their futures.
With the VEX AIR Drone, you can bring these real-world concepts into your classroom. Students will not only experience the excitement of flight, but also build skills in coding, engineering, and problem solving that prepare them for tomorrow’s challenges.
This page is your launchpad for teaching with VEX AIR. Here you’ll find everything you need—curriculum, resources, and support—to guide your students as they take flight and reach new heights.
Alaina Haws
Senior Education Developer, VEX Robotics
Classroom Implementation
The VEX AIR courses provides structured learning experiences designed to introduce drone operation, coding, and applied problem-solving. The courses are organized to build skills progressively, beginning with flying the drone in a simulation environment through the Virtual Flight course, moving to flying the physical drone in in an indoor flight area in the Controller Flight course, and advancing to autonomous programming in the Coding Flight course. These courses can be used with students in a classroom, independently, and by competition teams for preparation. They help with understanding how the drone works, how to fly it confidently indoors, and how to program it effectively.
The Virtual Flight course tile, showing an image of the VEX AIR Drone Controller connected to a laptop with a VEX AIR Drone shown on the screen.
The first course, Virtual Flight, introduces students to drone operation using the VEX AIR Flight Simulator. Students learn to use the VEX AIR Drone Controller to fly a virtual version of the drone with precision.
They learn to pick up and transport cargo using flight modules, and develop an understanding of basic flight principles. They then put all their learning to the test in a virtual flight competition in the course capstone.
To learn more about the Virtual Flight course, go here.
The Controller Flight Course Tile, showing the VEX AIR Drone Controller with the pre-flight checklist on the screen, and a drone with an arrow representing the drone's vision coming out of the front camera.
In the next course, Controller Flight, students take their experience with virtual drone flight into the physical world as they learn to fly the drone indoors with the controller.
Beginning with safety, setup, and pre-flight checklists, students learn how pitch, roll, and throttle map to 3D movement. They build confidence through taking control of orientation and heading before advancing to complex flight patterns and maneuvers. Students also complete missions using modules to transport objects and learn to capture images and videos while flying.
To learn more about the Controller Flight course, go here.
Coding Flight course tile showing a VEX AIR Drone over a VEXcode AIR blocks project.
Coming Soon!
The Coding Flight course integrates coding and computational thinking into drone operations, guiding students to program autonomous flights.
Students begin with coding basic flights, progress to incorporating sensors and telemetry data, and then learn to use the drone’s vision sensors to navigate and interact with the environment. Along the way, students practice coding the drone to pick up and transport cargo, culminating in a final autonomous Capstone Competition.
To see an overview of the Coding Flight course, go here.
Take Flight with VEX AIR
Before the First Flight
Excited to takeoff? Before you and your students get the drone in the air, there are some steps necessary to get everything set up and ready for that first flight.
Note: The VEX AIR Drone is intended for indoor use only. The altitude is limited to 8 feet (2.5 m). Do not operate the drone outdoors.
VEX AIR Drone Kit with all components from the kit laid out around the kit box.
As you and your students start to explore the VEX AIR Kit, it can be helpful to know what all you are seeing or where to find pieces as you move forward. See this article for an overview of the kit.
VEX AIR Drone with a highlight on the back area. An arrow points into the back zone with a battery on the other side of the arrow. A Callout on the battery shows that the "up" label is facing towards the top of the image and is the closest to the end being inserted into the drone.
Before each flight, students need to be sure the drone and controller are charged, paired, and ready for flight. Follow the steps in this article to learn more about preparing the drone and controller for the first flight.
To set up your classroom for safe indoor flight, start by defining a well-lit, obstacle-free flight area and clearly marking the boundaries so everyone knows where drone activity is happening. For more details on how to set up your space for safe flight with VEX AIR, see this article.
Prioritize Flight Safety
A human outline stands on the left holding a controller. in the middle is a set of arrows showing that there is 5 feet of distance between the human and the drone. The drone is on the right side.
Safety is key when working with a drone. It is important that the pilot and all people in the area surrounding the drone’s flight path are prepared, and that the space is set up for safe indoor flight. This includes considerations like:
  • A minimum of 5 feet of clear space around the drone in all directions including overhead.
  • Remove loose or lightweight objects from the flight zone and ensure a level takeoff surface
  • Tie back long hair and secure loose clothing
  • Clearly define and mark the flight area and post visible signage
  • Use clear classroom roles and routines
For a full list of safety preparations, see this article.
The drone's Propeller Lock helps to ensure a safe flight experience for students by engaging automatically if the drone detects handling when it is not in flight.
See this article for more information about the Propeller Lock.
To keep drone flights safe and productive, establish clear classroom routines so every student knows what to do before, during, and after a flight. Assign roles like Pilot, Co-Pilot, and Observer, and rotate them so everyone shares responsibility and gets a turn to fly. If multiple teams share one flight area, post a simple flight schedule and reinforce that anyone can call “CUT!” if they notice a safety concern.
See this article for strategies that support clear roles, shared responsibility, and consistent safety habits with VEX AIR.
Ready for Launch
Before taking flight, ensure the pilot understands how to:
  • Start the Default Fly project
  • Control the drone in the indoor flight area
  • Land the drone to end a project
A pre-flight checklist can help to ensure that everyone is prepared and safe for a flight. This article goes through that checklist and explains the Default Fly project.
Controlling the Drone
The drone can be controlled in two primary ways: manually using the controller and autonomously through coding in VEXcode AIR. The controller features dual joysticks and a built-in touch screen that displays live camera feeds and flight controls, helping to clearly see and manage the drone during flight. This controller is used to pilot both the physical drone and the virtual drone within the VEX AIR Flight Simulator.
Flight Simulator in the Rings Layout showing the drone mid-flight.
As a first step, students can fly a virtual version of the drone using the physical controller and build flight skills in a low-risk environment. In the VEX AIR Flight Simulator, they practice the same types of movements they would use with a real drone, helping them develop confidence and control. In addition, students begin to:
  • Develop safety habits related to the drone.
  • Use modules to interact and move objects.
  • Further their skills to complete advanced piloting maneuvers.
Drone in mid flight in the simulator. In the foreground are two badges showing progress in other Flight School missions.
Also in the VEX AIR Flight Simulator is Flight School.
Flight School turns students' simulator practice into measurable assessment through mission-based challenges directly from the Virtual Flight Course. The badges earned in Flight School allow students and educators to have a shared understanding of what mission success looks like, while providing real-time feedback and a concrete way to demonstrate performance from a virtual space.
Controller and Drone next to one another. The background shows an assortment of AIR kit pieces..
Once students are ready to move from the simulator to physical flight, they can take control of the drone using the same controller. This allows students to apply the piloting skills learned through virtual flight to the physical drone in an indoor flight area.
Coding in VEXcode AIR
VEXcode offers options to support learners at different experience levels:
  • VEXcode supports two primary coding methods: block-based and text-based coding.
    • Block-based coding uses a visual, drag-and-drop interface that allows users to focus on fundamental coding concepts—such as sequencing, loops, conditionals, and variables—without needing to worry about memorizing or typing syntax. This approach is ideal for building foundational understanding and confidence.
    • Text-based coding allows users to write code using Python. Text-based coding provides greater flexibility and mirrors real-world programming practices.
  • To help learners transition between these methods, VEXcode also includes Switch blocks. Switch blocks is an approach designed to scaffold the transition between block and text-based coding. They preserve the logical flow and visual structure of a block-based project while allowing users to type Python code directly within the blocks. This scaffolded approach supports a smooth progression from visual coding to fully text-based coding.
Continuing Support with VEX PD+
VEX Robotics offers comprehensive professional development resources available on pd.vex.com. VEX’s Professional Development Plus (PD+) platform is your destination for a wealth of resources designed to empower educators in the world of STEM. The VEX PD+ platform offers two tiers - a free tier and an All-Access paid tier.
VEX PD+ free tier
VEX PD+ All Access Dashboard page, with information on the user's account and certifications.
The VEX PD+ free tier includes access to:
  • Intro Courses: These self-paced online courses provide training on each VEX platform. Each course contains formative assessment and tracks your progress, making it easy for you to check your understanding and complete the course at your own pace. The VEX AIR Flight Educator Certification Course is designed to provide comprehensive context and preparation for educators, coaches, and adult leaders who will be supporting students or operating the VEX AIR Drone. Once you become certified, you gain access to the VEX Professional Learning Community (PLC). VEX AIR Flight Educator Certification coming soon!
  • Professional Learning Community (PLC): Join a network of global educators and VEX Experts, where you can learn, share, and benefit from a wealth of shared experiences. This is your virtual Teacher’s Lounge, where you can have meaningful dialogue, share expertise, ask questions, and work collaboratively to improve your STEM teaching and learning.
VEX PD+ paid tier (All-Access)
VEX PD+ All Access 1-1 sessions page with a calendar to schedule a session.
The VEX PD+ paid tier (All-Access) includes access to:
  • 1-on-1 Sessions: Schedule a 1-on-1 session with a VEX expert, get guidance and support tailored to your needs.
  • VEX Masterclasses: Video-based, expert-led courses that range from introductory ‘Getting Started’ courses to more advanced and pedagogy focused courses.
  • VEX Video Library: Access to hundreds of videos across a variety of topics and VEX platforms, available anytime and from anywhere.
  • VEX Robotics Educators Conference: An annual conference that brings the VEX PD+ Community together for in-person, hands-on learning, inspiring keynotes, and learning sessions with VEX education experts.
Every user will also have access to their own dashboard, which includes a tour of all the VEX PD+ features, allowing them to get started easily. We are continuously updating PD+ with new materials, ensuring our platform remains a rich, dynamic resource for our educators.
We are here to support you on your professional journey. If you have any questions, or feedback, you can use the feedback tool in VEX PD+. We're excited for you to explore, learn, and connect.
VEX AIR Drone Competition
VEX AIR Drone Competition is a team-based, game-style challenge where students pilot and program drones to complete objectives and score points in a match environment. It gives students an authentic way to apply flight skills, problem solving, and strategy while building confidence through repeated practice and competition.
Read more about this year’s game.
Common AIR Resources
