The VEX AIR Drone Kit comes with many parts in the case. Understanding the components in each area of the kit is helpful to make finding parts quick and efficient. The following article will provide an overview of the contents of each box that can be referred to and used in a classroom environment.
Note: The VEX AIR Drone is intended for indoor use only. The altitude is limited to 8 feet (2.5 m). Do not operate the drone outdoors.
This article describes each piece in the VEX AIR Kit and provides the following information in a table form from left to right:
- Part: This is the name of the part. Use this for reference while unboxing your kit.
- Photo: This is an image of the part. Use this for reference while unboxing your kit.
- Quantity: This is the quantity of each part provided. Use this to ensure you have the correct number of parts in each location while unboxing.
- Purpose: This column provides information about how the part or parts in that kit, bag, or box will be used while flying the VEX AIR Drone.
Location: This is an image of the kit with a highlight on where the part can be found. This information can also be used as a reminder of where a part is located.
- Some parts are found beneath others in the kit. Notes will be included to explain where certain items are located.
- Select the image to enlarge.
Lower Compartment of the VEX AIR Case
| Part | Photo | Quantity | Purpose | Location |
| VEX AIR Drone | 1 | Used to model real-world STEM concepts. | ||
| VEX AIR Drone Controller | 1 | Used to fly the VEX AIR Drone. | ||
| Passive Module | 1 |
Used with to manipulate objects. |
Note: The Passive Module comes attached to the VEX AIR Drone. |
Upper Compartment of the VEX AIR Case
To access the upper compartment of the VEX AIR Kit, undo the straps creating the section.
| 4-Blade Propellers (Grey) | 8 |
Replacement propellers for use on the Drone. |
| 4-Blade Propellers (Orange) | 4 |
| Landing Feet | 4 |
Replacement landing feet for use on the Drone. |
| Screwdriver | 1 |
Used to remove and replace propellors. |
| Propeller Screws | 12 |
Extra screws provided to replace those used for attaching propellers to the VEX AIR Drone. |
| Motorized Module Hook | 2 |
Connects to the Motorized Module to manipulate objects. |
| Motorized Module | 1 |
Used to manipulate objects with the Motorized Module Hook attached. |
| Passive Module Hook | 2 |
Connects to the Passive Module to manipulate objects. |
| Magnet Module | 1 |
Used to magnetize objects and move them from one location to another with the Drone. |
| VEX AIR Drone Battery - 900 mAh | 2 |
Used to power the VEX AIR Drone. |
| VEX AIR Drone Battery - 1200 mAh | 2 |
| Communication Headset | 1 |
Used for communication in conjunction with the controller. |
| Lanyard Strap | 1 |
Connected to the controller to allow for safe holding. |
| Lanyard Mounts | 2 |
Used to attach the lanyard to the controller. |
| USB Cable (A-C) 1m | 2 |
Used to connect to the USB Charger and charge the controller as well as connecting the controller to a computer for coding. |
| USB Cable (A-C) 300mm | 2 |
Used to connect to the USB Charger and charge the batteries. |
USB Charger (1-port, 15W) |
2 |
Used for charging the controller and batteries |
