Connecting and Powering the Jetson for VEX AI
Before the Jetson can be powered on and used, all devices used with the Jetson first need to be connected. The parts of the AI System contain enough hardware for two V5 Robots. However, this article will cover how to connect one Jetson.
Connection Outline
Diagram showing how VEX AI system components connect: V5 Brain links to motors, sensors, battery, and radio; Jetson Nano connects via USB to the V5 Brain, RealSense depth camera, GPS sensor, and Wi-Fi module with antennas; cables are color-coded by type.
The following is a diagram outlining how all parts of the VEX AI System connect. Use this diagram to connect all parts of the AI System to the Jetson.
View the Parts of the AI System article for a more detailed explanation of each part.
Connecting Tips
Jetson Nano board with Intel Wi-Fi module and two external antennas placed beside it.
Install the VEX AI Micro SD Card, Intel WI-FI Module, and WI-FI Antennas first.
Close-up of Jetson Nano highlighting the DC_EN jumper near the power connector.
The order of the USB slots in the Jetson do not matter. For example, the GPS Camera does not need to occupy the top left slot. Any of the four slots can be used in any order.
Ensure the correct cable is being used when connecting certain devices. For example, the GPS and Intel RealSense Cameras require specific cables.
Ensure the jumper labeled DC_EN on the Jetson is installed near the barrel connector.
Attach the Fan
Jetson Nano board and cooling fan shown separately before installation.
To prevent overheating, the fan needs to be attached to the Jetson Nano Module.
3D-printed Jetson case showing internal slot where the cooling fan can be placed.
Note: if you are using the suggested 3D print case for the Jetson, the fan does not need to be attached using screws, as there is a slot that the fan will sit in on the Jetson 3D case print.
Cooling fan mounted on top of the Jetson Nano with screws. The wires are oriented toward the USB ports.
If you are not using the suggested 3D print case for the Jetson, obtain the four screws needed to attach the fan. Place the fan on top of the Jetson Nano Module. Ensure the orientation is correct. The wires of the fan should face the front of the Jetson near the USB ports.
Close-up of Jetson Nano highlighting the connector where the fan cable attaches.
Locate on the Jetson where the fan will be attached.
Fan cable connected to the Jetson Nano header next to the cooling fan.
Attach the fan to the Jetson.
Insert the SD Card
The SD card included with the VEX AI Bundle should be placed in each Jetson.
Underside of Jetson Nano showing the location of the microSD card slot.
Locate the SD card slot on the underside of the Jetson module.
MicroSD card inserted into the Jetson Nano slot on the underside of the board.
Insert the provided SD card into the SD card slot on the Jetson module.
Powering the Jetson
The power to the Jetson comes from the V5 Brain that is attached to the V5 Battery. To power the Jetson and all devices connected to it, turn on the V5 Brain. Ensure both the V5 Brain and the V5 Battery are on.
<VEX 3-Wire to barrel plug cable used to supply power from the V5 Brain to the Jetson Nano.
The VEX 3-Wire Connector to Barrel Plug Cable will transfer the power from the V5 Brain to the Jetson.
2 3-Wire cables are plugged into the V5 Brain, showing connection used to power the Jetson.
Ensure the key of the 3-Wire cable is fully seated in the V5 Brain.
V5 Brain with its Power button highlighted.
To turn the Jetson off, simply turn off the V5 Brain.
