The following list contains the parts of the AI System and an explanation of their purpose. There are enough parts in the AI System for two V5 Robots.
- 2x V5 Robot Radios: for communication with other robots as well as connecting to VEX Link to view the Dashboard.
- 2x NVIDIA Jetson Nano: used to operate the cameras and AI software.
- 2x Micro SD Card with VEX AI Software: to be placed inside of the Jetson to ensure the AI hardware works with the AI software.
- 2x Cable for Jetson Nano to V5 Brain: to connect the Jetson to the V5 Brain.
- 2x VEX 3-Wire Connector to Barrel Plug Cable: to power the Jetson via the V5 Brain.
- 6x USB A to Micro Cables 18-inch: to connect the V5 Brain to the Jetson. Note that only one cable will be used per V5 Robot. The remaining 4 cables will be replacements if needed.
- 2x Intel Dual Band Wi-Fi for Jetson Nano: to connect the WI-FI Antennas to the Jetson.
- 4x Wi-Fi Antennas: to be connected on the Intel Dual Band Wi-Fi for Jetson Nano.
- 2x Cooling Fan for Jetson Nano: to ensure the Jetson does not overheat.
- 2x Intel D435 RealSense Depth Camera: to read the color and distance of objects on the field.
