3D Printing Housings for the VEX AI System
When working with the VEX AI System, there are suggested 3D print options available for the Jetson and the Intel Camera.
These 3D print suggestions can be used to house the Jetson and stabilize the cameras.
The print files can be downloaded:
3D Print Suggestion for the Jetson
When using the Jetson, it is important to create a type of case for it to ensure that it does not get damaged in competition.
There are two print files included for the Jetson:
3D-printed top cover for a Jetson Nano protective case with ventilation slots.
Jetson Nano Case Top
3D-printed bottom enclosure for a Jetson Nano case with mounting points and cutouts for ports.
Jetson Nano Case Bottom
Note that 2.6mm x 8mm self tapping screws are needed to secure the case in place.
3D Print Suggestion for the Intel Camera
When using the Intel Camera, it is important to create a type of case for it to ensure that it obtains the proper amount of ventilation as well as remains stabilized.
There are two print files included for the Intel Camera:
3D-printed top cover for an Intel camera case with a front opening and ventilation slots.
Intel Camera Case Top
3D-printed bottom mount for an Intel camera case with attachment points for inserts and screws.
Intel Camera Case Bottom
Note that four of the 276-6781 threaded motor inserts and two #6-32 x 0.5" screws are needed to secure the print in place.
