GO Educators Start Here
Welcome to teachGO.vex.com!
Welcome educators! You are here because you understand the importance of starting STEM early with your students. You know that providing them with fun, meaningful, hands-on STEM experiences is key to making sure they perceive themselves as capable and creative engineers, coders, and problem-solvers.
We understand that no matter the setting, teaching is challenging. All teachers are extremely busy, juggling a multitude of demands on their time and energy. Our extensive, flexible VEX GO educator resources make it easy to bring STEM, computer science, and robotics to life for students in active and relevant ways—whether you are brand-new to teaching STEM or a seasoned veteran.
As you teach with VEX GO in your setting, this start page can serve as your hub for VEX GO resources. On this page you will find access to everything you need to successfully teach with VEX GO, beginning with our immersive, project-based integrated STEM curriculum. You will also find information and links to our unparalleled teacher resources and support, and ways to take your students'—and your own—VEX GO experience even further.
Aimee Defoe
Senior Education Developer, VEX Robotics
Getting Started is Easy!
VEX offers free, online, integrated STEM curricula for teaching with VEX GO. Our Activities, Activity Series, and STEM Labs provide the support teachers need to easily immerse their students in collaborative, project-based STEM learning powered by the excitement of educational robotics.
And, if you are new to teaching coding, you can get your students started coding with blocks in VEXcode GO right away. Students can also code in Switch blocks, or Python.
Row of three VEX GO Activity tiles that each link to a VEX GO Activity.
VEX GO Activities are designed for independent student use. They offer cross-curricular connections and are great for short activities, learning centers, or extending or reteaching concepts from VEX GO STEM Labs.
Our VEX GO Discovery Activities introduce students to the VEX GO Kit through short, simple spatial reasoning experiences that use just 12 pieces from the VEX GO Kit!
Row of two VEX GO Activity Series tiles that each link to a VEX GO Activity Series.
VEX GO Activity Series are short sets of STEM Lessons based on engaging stories. Teacher Notes provide educators with direction on materials needed, setting up the activity, presenting the narrative, and implementing the activities successfully with students. Activity Series can be found on the STEM Labs page by filtering for 'Activity Series.'
Row of two VEX GO STEM Lab Unit tiles that each link to a VEX GO STEM Lab.
VEX GO STEM Labs are complete curricular units that can be integrated into your existing curriculum or utilized in a sequential order to provide comprehensive integrated STEM learning throughout the school year.
Each STEM Lab provides a wealth of resources for teachers. They function as an online teacher's manual and include:
Want to learn more about VEX GO Activities, Activity Series and STEM Labs? VEX Professional Development Plus is a comprehensive suite of professional development offerings designed to support all teachers. Read the next section for details.
Learn Alongside Your Students!
VEX provides a variety of teacher learning and support materials that are designed to meet you exactly where you are. Teachers have a wide range of STEM teaching experiences and may need to get started teaching with VEX GO quickly. The following resources provide the level of support you need now, whether it is a gradual introduction to teaching with VEX GO or a deep dive into STEM pedagogy. VEX gives you the voice and choice you need in your learning to advance your knowledge and skills in that way that is right for you.
Introductory Scope and Sequences
You don't need to be an engineer or a computer scientist to start teaching with VEX GO. The custom scope and sequences below will get your students started learning with GO right away—whileyou begin learning to teach with VEX GO at the same time! They present a series of easy-to-implement VEX GO lessons for your students alongside a curated, hands-on teacher learning experience for you. This is a great way to teach with VEX GO when your time is limited!
Check out these curated Scopes and Sequences for a 9-week implementation in the subject area of your choice. Scope and sequence documents are provided in an editable Google Doc format as well as in an easily printable pdf.
The VEX Library
The VEX Library is a free, searchable database of articles covering all aspects of teaching and learning with VEX. Quickly find information on any VEX GO topic you'd like to know more about, from using the VEX Classroom App to coding with VEXcode GO.
Coding with VEXcode GO
VEXcode offers options to support learners at different experience levels with two primary coding methods: block-based and text-based coding.
A screenshot of VEXcode GO block-based coding with a project in the workspace, using a combination of blocks and a switch block with a Python command typed in it. A note on the right describes the project, and on the left side the block toolbox shows available blocks.
  • Block-based coding uses a visual, drag-and-drop interface that allows users to focus on fundamental coding concepts—such as sequencing, loops, conditionals, and variables—without needing to worry about memorizing or typing syntax. This approach is ideal for building foundational understanding and confidence.
  • Text-based coding allows users to write code using Python. Text-based coding provides greater flexibility and mirrors real-world programming practices.
  • To help learners transition between these methods, VEXcode also includes Switch blocks. Switch is an approach designed to scaffold the transition between block and text-based coding. They preserve the logical flow and visual structure of a block-based project while allowing users to type Python code directly within the blocks. This scaffolded approach supports a smooth progression from visual coding to fully text-based coding. Learn more about using Switch to transition from blocks to text-based coding with this article.
These options make it possible to differentiate instruction in your environment. Whether you are just beginning or ready for more advanced coding, VEXcode GO provides a pathway for growth. VEXcode GO also includes built-in Help, based in the VEXcode API Reference, which explains what the blocks and commands are and how they work. This tool supports educators and students as they write and refine their projects. For more information about built-in Help, view this article.
VEX Professional Development Plus (PD+)
VEX Robotics offers comprehensive professional development resources available at pd.vex.com. VEX's Professional Development Plus (PD+) platform is your destination for a wealth of resources designed to empower educators in the world of STEM. The VEX PD+ platform offers two tiers - a free tier and an All-Access paid tier.
VEX PD+ free tier
Blank VEX GO Certificate that reads VEX GO Certification presented to Example Name.
The VEX PD+ free tier includes access to:
  • Intro Courses: These self-paced online certification courses provide training on each VEX platform. Each course contains formative assessment and tracks your progress, making it easy for you to check your understanding and complete the course at your own pace. Once you become certified, you gain access to the VEX Professional Learning Community (PLC).
  • Professional Learning Community (PLC): Join a network of global educators and VEX experts, where you can learn, share, and benefit from a wealth of shared experiences. This is your virtual Teacher's Lounge, where you can have meaningful dialogue, share expertise, ask questions, and work collaboratively to improve your STEM teaching and learning.
VEX PD+ paid tier (All-Access)
VEX PD+ 1-on-1 Session sign up page with a calendar for selecting the date and time of a session.
The VEX PD+ paid tier (All-Access) includes access to:
  • 1-on-1 Sessions: Schedule a 1-on-1 Session with a VEX expert to get guidance and support tailored to your needs.
  • VEX Masterclasses: Video-based, expert-led courses that range from introductory 'Getting Started' courses to more advanced and pedagogy focused courses.
  • VEX Video Library: Access to hundreds of videos across a variety of topics and VEX platforms, available anytime and from anywhere.
  • VEX Insights Articles: Timely articles providing expert information, analysis, and reflection on STEM education topics.
  • VEX Robotics Educators Conference: An annual conference that brings the VEX PD+ Community together for in-person, hands-on learning, inspiring keynotes, and learning sessions with VEX education experts.
Your PD+ Dashboard
PD+ Dashboard showing site navigation to the left, and links to Educational Resources for VEX GO to the right, including STEM Labs, Activities, Pacing guides, the VEX Library, and PD+ Community. Under that there are Quick Links for GO for Video Library, 1-on-1 Sessions, Insights. At the bottom of the page the user's GO certifications are shown.
Every user will also have access to their own dashboard, which includes a tour of all VEX PD+ features, allowing them to get started easily.
We are continuously updating PD+ with new materials, ensuring our platform remains a rich, dynamic resource for our educators.
We are here to support you on your professional journey. If you have any questions, or feedback, you can use the feedback tool in VEX PD+. We're excited for you to explore, learn, and connect.
Ready to Learn More?
VEX GO Competitions
Bring all the excitement and motivation of a VEX Robotics Competition to your students in their setting. VEX GO Competitions give teachers another way to bring authentic STEM learning to students as they collaborate to compete in thematic classroom competitions. With imagination-capturing themes—Mars Math Expedition, Ocean Science Exploration, Village Engineering Construction, and City Technology Rebuild—a VEX GO Competition takes students' learning further as they iterate on strategy and robot builds, and practice essential collaboration and teamwork skills. VEX GO Competitions make great culminating activities, year-end celebrations, and after-school projects!
Tile image for the Mars Math Expedition VEX GO Competition STEM Lab Unit.
Tile image for the Ocean Science Exploration VEX GO Competition STEM Lab Unit.
Tile image for the Village Engineering Construction VEX GO Competition STEM Lab Unit.
Tile image for the City Technology Rebuild VEX GO Competition STEM Lab Unit.
VEX GO Builds
Thumbnail image for the VEX GO Code Base Build Instructions.
At builds.vex.com you can find easy-to-follow build instructions for every VEX GO build in our curriculum—over 42 different builds! Project them for your students, or print them out to help facilitate building in your classroom.
Standards and Research
Standards-aligned and backed by research, the VEX GO curriculum sits on a solid foundation. Everything you need to share with stakeholders and decision-makers is organized and readily available.
Screenshot of the Content Standards section with links to the Where and How Standards are Met and the View Standards pages for VEX GO.
See all of the standards that are aligned with VEX GO STEM Lab units and Activities in one place at standards.vex.com.
Dig into the proven research that underlies the instructional strategies and approaches used in VEX GO curriculum at research.vex.com.
VEX Robotics Research logo.
VEX GO Pacing Guides
Our pacing guides make planning straightforward and easy. The GO Cumulative Pacing Guide contains all of our STEM Labs, Activities, and Activity series in one place that you can use to plan instructional sequences that meet your goals. The GO 1:1 Pacing Guide provides a suggested sequence of instruction that incorporates all of our GO curricular materials and can be used to plan daily STEM instruction for an entire school year!
VEX GO Printables
Collection of GO Printables including a parts poster, a blocks poster, and a project planner sheet.
At printables.vex.com you will find all of our VEX GO printables and posters in one place, allowing you to make student learning visible! Use them to help students plan coding projects, organize themselves for group work, and sketch robot designs; add them to the walls as classroom documentation; or use them to assess student learning.
VEX GO Camps
Everything you need to run exciting VEX GO Camps can be found at camps.vex.com, no matter your setting or the time of year. Camp manuals, template schedules, sample flyers, welcome letters and more take the guesswork out of planning and running a VEX GO camp.
Row of four VEX GO Camp tiles.
Funding
Whether you are starting or expanding your educational robotics program, funding ideas and support for grant writing can be found at grants.vex.com.
VEX Sales and Technical Support
Support.vex.com provides product assistance. Get help selecting products, getting quotes and making purchases as well as with technical issues or product repair and replacement. VEX offers support by phone, email and chat.
Common GO Resources
