The GO Competition – City Technology Rebuild 2.0 Playground brings the City Technology Rebuild VEX GO Competition into VEXcode VR. Students code a virtual VEX GO robot to complete the same kinds of tasks as the physical competition, such as delivering Medicine to the Hospital, delivering Supplies to the Emergency Shelter, raising fallen Power Lines and Trees, and clearing Rocks after a landslide. VEX GO Competition Playgrounds are available in VEXcode VR with a Premium license.
Use this article to introduce the Playground to your class. It starts with a slideshow written for students. The rest of the article explains what is in the slideshow, how to use it with your class, and how to support students as they code.
You do not need to build a robot or Field to use this Playground. If you have them, or want to learn more about them, see Connecting to the Physical Competition at the end of this article.
This slideshow is also available in Google Slides or Microsoft PowerPoint. Follow the steps in these articles to learn how to make a copy and customize using Google Drive or Microsoft Office.
What's in the Slideshow
The Playground has four Stages. Each Stage adds new objects and tasks, and the tasks from earlier Stages can still be scored. The slideshow follows the same order, in seven parts.
- Stage 1: Hospital Help (slides 1–5): Introduces the 2 pieces of Medicine at the Dock and the Hospital. Students remove the Medicine from the Dock, deliver it to the Hospital tile, and earn 2 points for each piece on a blue square inside the Hospital. They can also end the project on the red tile.
- Using the Playground (slides 6–15): Shows students how to change the camera view, hide and show the Playground, start and stop a project, read the score and time, get a certificate, and try again.
- Stage 1 Tasks (slide 16): Shows the Stage 1 tasks again so students can review them before moving on.
- Ready for More? (slide 17): Shows students how to pick the next Stage.
- Stage 2: Raise the Roof (slides 18–20): Adds the Emergency Shelter and the Fire Station. Students raise the Emergency Shelter roof, remove the Supplies from the Fire Station, and deliver them to the orange square inside the Emergency Shelter.
- Stage 3: Power Up (slides 21–23): Adds the fallen Power Lines and two fallen Trees. Students raise the Power Lines and each Tree to clear the roads.
- Stage 4: Landslide! (slides 24–26): Adds the landslide. Students trigger the landslide and move the Rocks to the red tile.
Each Stage ends with a slide listing its tasks and points. In Stages 2, 3, and 4, that slide also lists the tasks carried over from earlier Stages.
Using the Slideshow with Your Class
Before You Begin
Students need your VR Class Code to open this Playground. Share it before you start the slideshow so students are logged in and ready to follow along.
- Find your Class Code at vradmin.vex.com. You can share the code itself, or copy a direct link that logs students in without typing the code.
- Students with the code go to vr.vex.com, select Login Here, and enter the Class Code.
To learn more, see Logging Into a Class in VEXcode VR Enhanced or Premium. If you have not set up a class yet, see Creating Classes in the VEXcode VR Licensing System.
Presenting the Slideshow
The slideshow is written to be read with students, either projected for the whole class or shared so students can follow along on their own devices. Having the Playground open in VEXcode VR as you go lets students find each object and button as it is introduced.
A Note for Pacing: You do not need to show the whole slideshow at once. Slides 1–16 give students everything they need to start coding in Stage 1. Come back to the slideshow for Stages 2, 3, and 4 as your class is ready for each one.
Discussion Prompts
Use these optional prompts to check for understanding and get students thinking about strategy before they code.
Stage 1:
- Each piece of Medicine can score up to 3 points. What does your robot need to do to earn all 3?
- Your robot earns a point for ending on the red tile. How does that change what you plan for your robot to do last?
Using the Playground:
- When would Chase Camera be more helpful than Top Camera?
- You scored 1 point on your first run. What would you look at or change before you select Try Again?
Stage 2:
- Would you raise the Emergency Shelter roof before or after you deliver the Supplies? Why?
- How is raising the roof different from carrying Medicine?
Stage 3:
- Each fallen Tree scores 1 point. How will you plan a path that reaches both Trees?
- Which Stage 1 and Stage 2 tasks would you keep in your project, and which would you skip to make time for the Trees and Power Lines?
Stage 4:
- What has to happen before your robot can move a Rock to the red tile?
- Which task would you want your robot to do last? Why?
Running a Class Competition
Once students are comfortable with the Playground, you can turn it into a class competition with VEX Classroom Games. Add your teams, and Classroom Games runs the timer and keeps a leaderboard as you enter each team's score. You can project the Class Display so everyone can follow along, then present awards at the end.
Events save automatically, so a competition can pause at the end of class and pick up again next time.
- To set up a competition using this Playground, see City Technology Rebuild in VEX Classroom Games.
- To learn how Classroom Games works, see Getting Started with VEX Classroom Games.
Supporting Students as They Code
After the slideshow, students are ready to start coding. Knowing how the robot works and where to find the example projects will help you get them started and answer their questions as they go.
About the Robot
Students code a virtual Competition Advanced Hero Robot 2.0. It has the same dimensions, motors, and sensors as the physical robot from the VEX GO Competitions.
The robot lifts objects with its Arm and long front forks. Its Front Eye Sensor sits under the forks, so the sensor moves up and down with the Arm.
This robot uses the standard VEXcode VR blocks and also has its own blocks for the Arm Motor and the Front Eye Sensor. Use the VEX API to preview these blocks before class, or point students to it when they want to know how a block works.
- To learn more about the Playground buttons, see Using the Playground Features in the GO Competition Playgrounds.
- For the blocks that are specific to this robot, see Robot-Specific Blocks in the VEX API.
Getting Started with Example Projects
Example projects give students a working starting point for one part of the game.
Select the File menu, in the left corner of the Toolbar.
Select Open Examples.
Select an example project. The GO Competition example projects show a VR Competition Advanced Hero Robot in their icons, and each one opens on the Stage it was made for.
Have students run the example first and watch what the robot does. Then they can change one thing at a time to see the effect, and build on it to make their own project.
- For tips on using example projects in class, see Using Example Projects with the GO Competition Playgrounds.
- For students who are ready for more of a challenge, see Using the Navigation Kit in a VEXcode VR Playground.
The City Technology Rebuild is also a physical VEX GO Competition. Students build the Field in four stages from VEX GO parts, and each stage matches a Stage in this Playground. They build a Competition Advanced Hero Robot 2.0, the same robot they code in VEXcode VR, and drive it to complete the tasks.
The Playground and the physical competition work well together or on their own. Here are a few ways to connect them:
- Using only the Playground: Show students the Field and the story behind the competition to give the tasks a real-world context.
- Using both: Have students code in the Playground and drive on the Field, so they practice the same tasks in two ways.
- Already running a physical competition: Use the Playground to give every student time to practice and plan a strategy, even when the Field is in use.
Use these resources to learn more about the physical competition.
- For the story behind the competition, task videos, and Labs for each stage, see the City Technology Rebuild STEM Lab Unit.
- To see how the Field is built at each stage, see the City Technology Rebuild build instructions on the VEX GO Build Instructions page.
- For an overview of the steps to start a physical competition, see Getting Started with the VEX GO Competition.
