Introducing the GO Competition – Mars Math Expedition 2.0 Playground to Your Class
The GO Competition – Mars Math Expedition 2.0 Playground brings the Mars Math Expedition VEX GO Competition into VEXcode VR. Students code a virtual VEX GO robot to complete the same kinds of tasks as the physical competition, such as collecting samples from craters, delivering them to the Lab, getting the Landing Site ready, and delivering Fuel Cells to the Rocket Ship. VEX GO Competition Playgrounds are available in VEXcode VR with a Premium license.
Use this article to introduce the Playground to your class. It starts with a slideshow written for students. The rest of the article explains what is in the slideshow, how to use it with your class, and how to support students as they code.
You do not need to build a robot or Field to use this Playground. If you have them, or want to learn more about them, see Connecting to the Physical Competition at the end of this article.
This slideshow is also available in Google Slides or Microsoft PowerPoint. Follow the steps in these articles to learn how to make a copy and customize using Google Drive or Microsoft Office.
What's in the Slideshow
The Playground has four Stages. Each Stage adds new objects and tasks, and the tasks from earlier Stages can still be scored. The slideshow follows the same order, in seven parts.
  • Stage 1: Crater Collection (slides 1–5): Introduces the samples and the Rover in the craters, and the two tasks students can score.
  • Using the Playground (slides 6–15): Shows students how to change the camera view, hide and show the Playground, start and stop a project, read the score and time, get a certificate, and try again.
  • Stage 1 Tasks (slide 16): Shows the Stage 1 tasks again so students can review them before moving on.
  • Ready for More? (slide 17): Shows students how to pick the next Stage.
  • Stage 2: Lift onto the Lab (slides 18–20): Adds the Lab. Students can place samples inside the Lab, on top of it, or on the matching color square for 1, 2, or 3 points.
  • Stage 3: Blast Off! (slides 21–24): Adds the Solar Panel, Landing Site, helicopter, and Rocket Ship. Students also learn to select the Helicopter button once the Landing Site is clear.
  • Stage 4: Fuel Cell Frenzy (slides 25–27): Adds the Fuel Cells and the three tasks for removing and delivering them.
Each Stage ends with a slide listing every task and its points, including the tasks carried over from earlier Stages.
Using the Slideshow with Your Class
Before You Begin
Login screen from VEXcode VR with a text box that has the label Enter Class Code or Team Number.
Students need your VR Class Code to open this Playground. Share it before you start the slideshow so students are logged in and ready to follow along.
  • Find your Class Code at vradmin.vex.com. You can share the code itself, or copy a direct link that logs students in without typing the code.
  • Students with the code go to vr.vex.com, select Login Here, and enter the Class Code.
To learn more, see Logging Into a Class in VEXcode VR Enhanced or Premium. If you have not set up a class yet, see Creating Classes in the VEXcode VR Licensing System.
Presenting the Slideshow
The slideshow is written to be read with students, either projected for the whole class or shared so students can follow along on their own devices. Having the Playground open in VEXcode VR as you go lets students find each object and button as it is introduced.
A Note for Pacing: You do not need to show the whole slideshow at once. Slides 1–16 give students everything they need to start coding in Stage 1. Come back to the slideshow for Stages 2, 3, and 4 as your class is ready for each one.
Discussion Prompts
Use these optional prompts to check for understanding and get students thinking about strategy before they code.
  • Stage 1:
    • Which crater would you send your robot to first? Why?
    • The Rover is stuck in its own small crater. How might rescuing it be different from collecting a sample?
  • Using the Playground:
    • When would Chase Camera be more helpful than Top Camera?
    • You scored 1 point on your first run. What would you look at or change before you select Try Again?
  • Stage 2:
    • A sample on its matching color square is worth 3 points. How many samples inside the Lab would earn the same score?
    • Why do you think placing a sample on top of the Lab is worth more than placing it inside?
  • Stage 3:
    • Which task would you want your robot to do last? Why?
    • What has to happen before you select Helicopter?
  • Stage 4:
    • A Fuel Cell can be delivered to the Rocket Ship or the Landing Site. Which would you try first? Why?
    • Pushing a cradle down makes the Fuel Cells roll out. How does that movement compare to other tasks around the Playground?
Running a Class Competition
Once students are comfortable with the Playground, you can turn it into a class competition with VEX Classroom Games. Add your teams, and Classroom Games runs the timer and keeps a leaderboard as you enter each team's score. You can project the Class Display so everyone can follow along, then present awards at the end.
Events save automatically, so a competition can pause at the end of class and pick up again next time.
Supporting Students as They Code
After the slideshow, students are ready to start coding. Knowing how the robot works and where to find the example projects will help you get them started and answer their questions as they go.
About the Robot
Students code a virtual Competition Advanced Hero Robot 2.0. It has the same dimensions, motors, and sensors as the physical robot from the VEX GO Competitions.
VEX GO Competition Advanced Hero Bot.
The robot lifts objects with its Arm and long front forks. Its Front Eye Sensor sits under the forks, so the sensor moves up and down with the Arm.
This robot uses the standard VEXcode VR blocks and also has its own blocks for the Arm Motor and the Front Eye Sensor. Use the VEX API to preview these blocks before class, or point students to it when they want to know how a block works.
Getting Started with Example Projects
Example projects give students a working starting point for one part of the game, such as picking up a sample or tilting the Solar Panel.
VEXcode VR toolbar with the File menu highlighted
Select the File menu, in the left corner of the Toolbar.
VEXcode VR File menu with Open Examples highlighted
Select Open Examples.
VEXcode VR example projects with the Clear the Landing Site example highlighted
Select an example project. The GO Competition example projects show a VR Competition Advanced Hero Robot in their icons.
Clear the Landing Site example project with its note highlighted, listing the Playground and Stage
The example project opens on the Stage it was made for. The note at the top of the project describes what the project does.
Have students run the example first and watch what the robot does. Then they can change one thing at a time to see the effect, and build on it to make their own project.
The Mars Math Expedition is also a physical VEX GO Competition. Students build the Field in four stages from VEX GO parts, and each stage matches a Stage in this Playground. They build a Competition Advanced Hero Robot 2.0, the same robot they code in VEXcode VR, and drive it to complete the tasks.
Four students standing behind a VEX GO Competition field. The boy on the right is holding a tablet to drive the GO robot on the field. The other three are watching his progress and pointing at the robot.
The Playground and the physical competition work well together or on their own. Here are a few ways to connect them:
  • Using only the Playground: Show students the Field and the story behind the competition to give the tasks a real-world context.
  • Using both: Have students code in the Playground and drive on the Field, so they practice the same tasks in two ways.
  • Already running a physical competition: Use the Playground to give every student time to practice and plan a strategy, even when the Field is in use.
Use these resources to learn more about the physical competition.
