Running a Head-to-Head Tournament in VEX Classroom Games
In a Head-to-Head tournament, two teams face off in each match and the winner moves on, round by round, until one team is the champion. VEX Classroom Games builds the bracket and advances the winners for you, so you can keep the focus on the matches.
This article shows how to set up the bracket, record each match, and follow it to a champion.
Setting Up a Head-to-Head Event
Screenshot of the VEX Classroom Games home page with the VEX IQ platform highlighted.
Head-to-Head games are available for several VEX platforms. This article uses Tug of War for VEX IQ as an example.
From the VEX Classroom Games home page, select VEX IQ.
Screenshot of the VEX IQ games page with Head-to-Head selected in the Competition format menu.
To narrow the list to Head-to-Head games like Tug of War, select Head-to-Head from the Competition format menu.
Screenshot of the Tug of War game card with the Explore game button highlighted.
Select Explore game on the Tug of War card.
The game page describes the challenge and links to its learning resources.
Screenshot of the Tug of War game page with the Set up this game button highlighted.
Select Set up this game.
The setup page opens with the event settings for this game.
Screenshot of the Tug of War Event settings with the single elimination description highlighted.
Check the format description under Event settings.
Head-to-Head events are single elimination, and teams are randomly paired. A team without an opponent gets a bye, which moves it to the next round automatically.
Screenshot of the Teams section of the setup page with the Number of teams slider and team names highlighted.
Set the Number of teams, then type each team’s name.
You need at least two teams. In games played by Alliances, like Team Freeze Tag, two Alliances play each match instead of two teams.
Screenshot of the bottom of the setup page with the Start event button highlighted.
Select Start event.
The bracket is created with random pairings, and your event opens to the first match.
Running Each Match
Screenshot of the Matches tab showing Round 1, Match 2 between the Red and Blue teams, highlighted.
The Matches tab shows the next match in the bracket.
The round and match number appear above the Red and Blue teams, so you know which robots to place on the field.
Screenshot of the Select the winning team buttons for a Tug of War match, highlighted.
When the match ends, select the winning team under Select the winning team.
The winner advances right away and the next match loads. If the match ends in a draw, replay it before you select a winner.
Screenshot of a Robot Soccer match with the score fields and Record winner and advance button highlighted.
In games scored with points, like Robot Soccer, enter both teams’ scores and select Record winner and advance.
The team with the higher score advances. A tie can’t be recorded, so replay the match and enter the deciding scores.
Screenshot of the Last match summary with the Reopen match button highlighted.
If you selected the wrong winner, select Reopen match.
This clears the last result and makes that match the current match again, so you can record the correct winner.
Following the Bracket
Screenshot of the Bracket tab with the next match shown under Up next. The Bracket tab and Up next are highlighted.
Select the Bracket tab.
The bracket opens to the current round, with the next match shown under Up next.
Screenshot of the full tournament bracket with checkmarks next to the winners, with the round menu highlighted.
Select Full bracket from the round menu to see every match at once.
To go back to one round at a time, use the arrow buttons on either side of the round menu. A checkmark marks the winner of each completed match.
Screenshot of the Standings tab for a finished Tug of War bracket, with the Standings tab highlighted.
Select the Standings tab.
Teams are ranked by wins, so the champion is first and the other finalist is second. In games scored with points, like Robot Soccer, ties are broken by total score. Teams that are still tied share a rank.
Screenshot of the class display for a Tug of War event, showing the next match and the Round 1 matches.
To show the bracket to your class, select Open class display from your event.
The class display follows the bracket and shows the next match. After the final match, it switches to the final standings.
Finishing the Tournament
Screenshot of the Matches tab after the final match, with the Tournament champion highlighted.
After the final match, the Matches tab shows the tournament champion.
To change the final result, select Reopen match.
Screenshot of the Awards tab with the Champion award automatically assigned to the bracket winner. The Awards tab and Champion award are highlighted.
Select the Awards tab.
The Champion award is filled in automatically with the winner of the bracket. Assign any other awards, then select Finish event.
To present awards and finish the event, see Assigning Awards in VEX Classroom Games.
To learn more about the class display, see Using the Class Display in VEX Classroom Games.
For more on scoring other types of games, see Scoring Events in VEX Classroom Games.
