Installing VEXcode EXP on Windows
First, download VEXcode EXP if you have not done so already.
VEXcode EXP Installer icon as shown after downloading it for Windows.
Select the VEXcode EXP Installer to begin installation.
VEXcode EXP Setup pop up window that reads Uninstalling old version of VEXcode EXP. The OK button below is highlighted.
If there is a previous version of VEXcode EXP on the computer, the installer will first uninstall the old version of VEXcode. Select OK.
Note:
You might have to grant permission for the app to make changes to your computer.
VEXcode EXP Setup window showing the End User License Agreement. The I Agree button below is highlighted.
The License Agreement will appear. After you have finished reading through the EULA, select I Agree.
VEXcode EXP Setup window showing the Installation Options, with a choice between installing the application for only the current user or all users. The Install button below is highlighted.
Choose the installation button for the installer, whether it will be installed only for the current user, or for all users on the computer. Once chosen, select Install.
VEXcode EXP Setup window showing the Completing VEXcode EXP Setup screen. The Finish button below is highlighted.
Wait for the installation to complete, then select Finish.
VEXcode EXP application icon installed on Windows.
Launch VEXcode EXP using the desktop shortcut.
VEXcode EXP application installed and opened on Windows.
Begin working in VEXcode EXP.
Create a new project to get started with coding in VEXcode EXP!
