Configuring a 2-Motor Drivetrain in VEXcode EXP
When starting to program with VEXcode EXP, blocks from the Drivetrain category will not appear in the Toolbox until a Drivetrain has been configured.
You can only configure one Drivetrain per project.
Adding a Drivetrain
VEXcode EXP Toolbar with the Devices icon highlighted in between the Code Viewer and the Print Console icons.
To configure a Drivetrain, select the Devices icon to open the Devices window.
VEXcode EXP Devices menu with the Add a device button highlighted.
Select “Add a device.”
VEXcode EXP Devices menu after the Add a device button has been selected. The Drivetrain 2 motor option is highlighted.
Select 'Drivetrain 2-Motor.'
Two screenshots side by side that show the Port Selection menu being used to change already set Port numbers for the Motors. Previously selected Ports will show green, and after selecting the new ones the user can press Done to save the changes.
Select which ports the Left Motors and Right Motors are attached to on the VEX EXP Brain. Ports that are already configured for other devices will be unavailable.
VEXcode EXP Devices menu after selecting the Drivetrain Ports and with the Drivetrain Settings screen shown. Below, the Done button is highlighted.
Once the Drivetrain has been configured, select “Done” to submit the device to the configuration or “Cancel” to return back to the Devices menu.
Note: Selecting “Cancel” will undo any changes you have made to the device and will not be a part of the configuration.
Changing a Drivetrain’s Port Numbers
VEXcode EXP Devices window with the Drivetrain Settings menu shown. Above, the icons of the Left Motor and Right Motor Ports are highlighted.
You can change the port numbers for the Left Motors and Right Motors in the Drivetrain by selecting a plug icon in the top right corner of the Options screen.
Select a different port on the Port Selection screen and the port number will turn green.
Then, select Done to submit the change.
Changing a Drivetrain’s Wheel Size
VEXcode EXP Devices window with the Drivetrain Settings menu shown. The Wheel Size dropdown menu is highlighted.
You can change the wheel size for the Drivetrain by selecting the drop down menu under “Wheel Size.”
Changing a Drivetrain’s Gear Ratio
VEXcode EXP Devices window with the Drivetrain Settings menu shown. The Gear Ratio options are highlighted. There is an input field and an output field, and a symbol indicating that the numbers represent a ratio.
You can change the gear ratio for the Drivetrain by entering values in the “Input” and “Output” boxes.
Reversing a Drivetrain
VEXcode EXP Devices window with the Drivetrain Settings menu shown. The directional arrows have been highlighted to indicate that the Drivetrain's direction can be changed.
The Options screen also allows the direction of the Drivetrain to be reversed.
Deleting a Drivetrain
VEXcode EXP Devices window with the Drivetrain Settings menu shown. Below, the Delete button is highlighted.
A Drivetrain can also be deleted by selecting the “Delete” option at the bottom of the screen.
