Create a PD+ Account
Welcome to VEX PD+! All users possessing a VEX account, including previous VEX Certification users, are entitled to a complementary set of resources within VEX Professional Development Plus. These resources will kick-start your VEX journey with free Intro Courses and Competition Courses, access to the Professional Learning Community upon earning a certificate, and connection with other certified educators around the world through the VEX Passport.
Login to VEX PD+
PD+ homepage with the Login option in the upper right corner highlighted.
Start by going to pd.vex.com and select Login.
Screenshot of the Login screen reading Login to an existing account, with spaces to enter your email and password, and a login button on the bottom left.
Login using your VEX Account.
Don’t have a VEX Account? Fill out this form to register for a VEX Account.
Then navigate back to pd.vex.com after creating your account, and log in.
PD+ Get Started Tour, with the Next button in the bottom of the prompt window highlighted.
Once logged in, you will see the dashboard. Because you have not activated a license key, some features will be locked. You will also see a pop-up window offering a tour of PD+. Select Next to start the tour.
PD+ Get Started Tour dialog with the Previous and Next buttons on the bottom left and right corners respectively, highlighted.
You will be provided with a high-level overview of each PD+ feature. Select Next to advance to the next feature, or Previous to go back to the last feature.
PD+ Get Started Tour dialog with the Finish Tour button highlighted.
When you are finished with the tour, select Finish Tour.
PD+ Get Started Tour dialog with the Skip Tour option in the upper right highlighted.
If you do not wish to take the tour, select Skip Tour.
PD+ Navigation menu with Masterclasses, Intro Course, and Competition Course options highlighted.
Now you will be able to access Intro Courses and Competition Courses to earn certifications. Become a PD+ All-Access member to unlock VEX Masterclasses, comprehensive, guided lessons led by VEX experts.
PD+ course tile examples showing options for Intro Courses, Competition Courses, and Masterclasses across multiple platforms.
For more information about VEX Masterclasses, Intro Courses, and Competition Courses, view this article: Understanding the Pathways to VEX Certifications.
PD+ Navigation menu with the Community option highlighted.
You can view all discussions in the PD+ Community to begin learning from other educators around the world. After completing a free Intro Course or Competition Course and earning a certificate, you will be able to create your own posts in the discussion for the corresponding platform if you have a free PD+ Account.
By becoming a PD+ All-Access member, you will be able to participate in discussions for all VEX platforms.
For more information about the Community, view this section of articles in the VEX Library.
PD+ Navigation menu with the Passport option highlighted.
Once you have earned a certification and enabled your profile permissions, you can also connect with other certified VEX educators around the world through the VEX Passport.
For more information about the Passport, view this article.
Activating a License Key
PD+ Quick Links navigation in the PD+ Dashboard with the Activate License option in the lower left corner highlighted.
To activate a VEX PD+ License Key, follow the steps in this article.
If you are having trouble logging in or need additional support, click here.
