The VEX Passport allows users to connect with other certified VEX educators around the world. Each connection you make helps to further personalize your professional learning community.
Note: You will need to have a PD+ account – Free or All-Access – to access the Passport and connect with others. For more information on creating a PD+ account, view this article.
What is the VEX Passport?
The VEX Passport is a feature within PD+ that highlights educators around the world who have earned VEX certifications through VEX Intro Courses, VEX Masterclasses, and Competition Courses.
The interactive map shows the numbers of total certified educators around the globe. You can explore the map to see where certified educators are located, and connect with them individually.
In order to have your information displayed in the Passport Map, you will need to enable your profile information and permissions.
Sharing Your Profile
Update Your Profile Information
Upon first opening the VEX Passport, you will be prompted to update your profile information.
You can enter the name you wish to have displayed, your school affiliation, and brief biographical information you would like others to know about you.
Scroll down in the window to complete your location details. You can enter your city, region, postal code, and country.
Once you have edited your profile information, scroll to the bottom of the window and select Save VEX Passport Settings.
You can edit or update your profile information at any time by selecting Edit Profile >.
Note: Your profile image is pulled directly from your VEX Login information. To update your profile image, visit login.vex.com.
Update Your Permissions
You must enable permissions to allow others to view your VEX Passport profile information and connect with you through the VEX Passport.
Select Edit Permissions > to open the permissions options.
By default, all of the permissions options are deselected. You must enable the optional profile details that you would like to have displayed.
Select Allow users to connect to enable other educators to send you a connection request.
Select Save VEX Passport Settings to enable your desired permissions.
Now your profile information will be viewable alongside the interactive map.
Searching in the VEX Passport
You can search in two ways – by location, or by VEX platform.
Search by Location
You can enter the country or city you wish to search for in the Search bar. Select the Search button to see the results on the map.
The map will then zoom in on the entered country or city, and display the specific locations of VEX certified educators within that region.
Numbered pins indicate how many educators are located near that area. You can zoom in further on the map, or select a numbered pin to zoom in on that area.
Select a location icon to see the information of the certified educator it represents.
You will be able to see the profile information that educator has publicly enabled, as well as the platforms in which they are certified and their approximate location.
Search by VEX Platform
You can also search for educators who are certified in specific VEX platforms.
Selecting a VEX platform will display the global educators certified in that platform.
The numbers shown in the interactive map will now reflect only the educators in the selected platform. In the example shown here, only the VEX 123 educators are shown in the map.
You can select multiple platforms to see all educators certified in all selected platforms.
Connecting with Other Educators
You can also browse the map directly to find educators to connect with. If an educator has enabled the Allow users to connect permission in their VEX Passport settings, you can send them a connection request.
On the Passport map, numbered pins indicate groups of educators located in an area. Select a group to zoom in on that area.
Zoom in until individual pins appear.
Select a pin to view that educator's name.
Select Request to connect to connect with that educator. This automatically sends an email to the educator notifying them of your request.
Total Certified Educators
Statistics below the interactive map show the total numbers of VEX certified educators globally. Each platform shows the number of completed certifications within it. The statistics below show the number of total unique educators that have been certified, and the total certifications they have earned.
