The VEX AIR Drone Controller acts as the command center for the VEX AIR Drone. It is where projects are downloaded from VEXcode AIR, where live information from the drone is displayed, and how pilots directly control the drone's actions using its joysticks, programmable buttons, and touchscreen.
Charging the Controller
To charge the controller, connect it to a power source via its USB-C port.
Turn on the Controller
To turn on the controller, press and hold the Power button until the indicator LED begins flashing white, then release. This animation shows this process.
To learn more about getting the controller ready for its first flight, view this article.
Controller Features
LED Indicator
The controller has an LED indicator as part of the Power button that shows the status of the controller. These states are described in the tables below.
| Color | State | Meaning |
| Blue | Blinking | Propeller Lock is enabled. |
| Green | Solid | Controller > 20% battery, not paired with a drone. |
| Green | Blinking | Controller > 20% battery, paired with a drone. |
| Red | Solid | Controller < 20% battery, not paired with a drone. |
| Red | Blinking | Controller < 20% battery, paired with a drone. |
| White | Blinking | The power button can be released to turn on or turn off the controller. |
If the controller is off, the LED Indicator will only turn on while the controller is being charged.
| Green | Solid | Controller is fully charged (100%). |
| Red | Blinking | Controller is actively charging. |
System Buttons
The controller includes four system buttons that perform predefined functions. The Power button and three additional buttons:
The Change View button cycles through what will be displayed on the controller's screen.
- Forward video - The feed from the forward-facing Vision Sensor.
- Downward video - The feed from the downward-facing Vision Sensor.
User Screen - The controller's print area, where all Screen blocks or commands will print to. This view is only available while a project is running.
- Note: During the
default_flyproject, data and buttons are printed to the User Screen for project settings.
- Note: During the
The Propeller Lock button which will keep the paired drone grounded until the Power button on the drone is pressed.
While the paired drone has its propellers locked, both LED indicators on the drone and controller will blink blue. See this article for more information about this feature.
The Takeoff & Land button opens the project menu, allowing a project to be selected and started.
When a project is already running, and the drone is flying, pressing the button opens the landing menu.
Programmable Buttons
Joysticks
The joysticks are used to control the motion of the drone during flight. To learn more about using the joysticks to control the drone in the default_fly project, view this article.
For more information about coding with controller's joystick axes, view the VEXcode API Reference for Blocks or Python.
The controller's joysticks must be installed before flight. They are stored on the back of the controller.
The joysticks can then be screwed into the joystick slots on the front of the controller.
Controller Interface
The controller features a touchscreen interface for displaying drone information, status, settings, projects, and more.
Display View
The controller's built-in screen shows the current camera view or the User Screen in the center of the interface. By default, a live video feed from the drone's forward-facing Vision Sensor is shown.
This can be switched to the downward-facing Vision Sensor video feed or the User Screen by pressing the Change View button.
Instrument data is shown on the bottom of this section of the screen, displaying the real time data about the drone's position and movement.
Instrument data can be toggled on or off within the Controller Settings (see below) or within the default_fly project.
Controller Settings
The information and buttons on the left side of the interface reference the controller.
Controller Battery
The top left corner shows the controller's current battery level.
Connection Status
The connection status of the controller is shown below the battery information. There are two connection icons:
- USB connection - When the controller is connected via USB cable, the USB icon will appear.
- Drone connection - When the controller and drone are actively connected, the connection icon will show green (as seen here). It will show white when disconnected.
Controller Settings
The Controller Settings menu enables you to toggle settings and adjust various elements based on your preferences.
Controller settings include:
- Reticle – Shows or hides the reticle on the forward or downward camera view displays.
- Instruments - Shows or hides the instrument panel with telemetry data on the bottom of the screen.
- Notifications - Shows or hides the notifications that appear in the lower left corner of the screen.
- Mission Logs - Turns Mission Log data recording on or off.
- Units - Sets the units displayed on the screen to Metric or Imperial.
- Volume - Adjusts the controller volume up or down. The default volume is 50%.
- Reset Settings - Allows for all settings to be reverted back to the default.
- Firmware - Lists the current firmware version of the controller.
Controller Status
Information about various controller connections and buttons is shown here.
To calibrate the controller's joysticks, select the Calibrate Sticks button in this menu, and follow the prompts.
Mission Logs
Information about drone missions and activity is displayed here. Select Clear to clear the Mission Log information. Select the X button to close the window.
Past Mission Data
Data from previous missions or projects is available in this menu. This is where you will find captured video or images from the drone's cameras as well. Select a mission to view the data.
View this article to learn about downloading images and video from missions.
Select the Trash icon beside a mission to delete its data from the controller.
Drone Settings
The buttons and information on the right side of the interface reference the drone.
Drone Battery
The top right corner shows the drone's current battery level, as well as the approximate amount of time left until the battery will need to be charged.
Module
The Module indicator is below the battery information. This icon indicates which, if any, of the Modules are attached to the drone – Magnet (as shown here), Motorized Hook, or a dotted line icon indicates the Passive Hook Module or no Module attached.
Drone Settings
The Drone Settings menu enables you to adjust and set various elements based on your environment and preferences.
Drone settings include:
- Max Altitude - Sets the maximum height (in meters) that the drone can fly to.
Steering Mode - Sets the perspective for the drone's movements.
- Standard - movement is oriented based on the front of the drone. (Default)
- Headless - movement is oriented based on the starting position of the drone.
Movement Mode - Sets the drone's movement style.
- Precision - Slower, camera-stabilized mode for accurate control and learning. (Default)
- Balanced - Faster, camera-stabilized mode for smooth, responsive flight.
- Performance - High-speed, non-stabilized mode for advanced maneuvering.
- Firmware - Lists the current firmware version of the drone.
Drone Status
Information about various aspects of the drone and its activity are shown here.
The Module section shows which Module is attached, and has a button for activating that module.
Drone Dashboard
The Drone Dashboard shows real time data about the drone's position, acceleration, and distance from objects based on sensor data. You can refer to the Drone Dashboard while flying to help you better understand the drone's position in the air.
Capture Forward Camera
Select the Video button (on the left) to begin recording the camera feed from the forward-facing Vision Sensor.
Select the Image button (on the right) to capture the still image from the forward-facing Vision Sensor.
Capture Downward Camera
Select the Video button (on the left) to begin recording the camera feed from the downward-facing Vision Sensor.
Select the Image button (on the right) to capture the still image from the downward-facing Vision Sensor.
Using the Controller Lanyard
The VEX AIR Drone Controller comes with a lanyard that attaches to the bottom of the controller. Wearing the lanyard helps prevent the controller from falling if the pilot loses grip during a flight session.
First, screw the anchor pins into the bottom of the controller.
Then clip the lanyard onto the anchor pins to attach the lanyard to the controller.
