Pre-Flight Checks & Takeoff
Before flight operations begin, a thorough pre-flight checklist should be completed to ensure all systems are ready. The VEX AIR Drone and VEX AIR Drone Controller must be charged, powered on, paired, and all safety checks must be passed.
When using the default_fly project, it is important to understand the safety checks as well as the joystick controls, and how to land the drone at the end of the project.
In addition to the checks detailed below, use the following resources to help you establish intentional safety check procedures with students:
  • Pre-Flight Checklist – This checklist is included in the Mission Logs for all Controller Flight Course missions. You can also access it here (Google Doc / .docx / .pdf).
  • Setting Up Your Space for Safe Flight This article gives guidance for defining an indoor flight area in your space, and other environmental considerations when taking flight.
  • Classroom Management for Teaching with VEX AIR This article gives strategies and guidance for flight session logistics, student roles, and adult and student responsibilities before, during, and after flight.
Note: The VEX AIR Drone is intended for indoor use only. The altitude is limited to 8 feet (2.5 m). Do not operate the drone outdoors.
VEX AIR Drone Controller screen with a regulatory notice pop up in the center that reads For indoor use only. Do not operate outdoors. Obey the local drone laws. An I Agree button is below the text centered on the screen.
Each time you turn on your VEX AIR Drone Controller, a regulatory notice will appear. This is a reminder that the VEX AIR Drone is intended for indoor use only and should not be flown outside. Select I Agree to acknowledge your understanding and continue using the controller.
Controller Battery Check
If the controller battery is not over 20% charged, your battery will need charged before beginning your flight.
Fully charge the controller by connecting it to a power source via its USB-C port.
After the controller has charged, check its battery level. Turn on the controller by pressing and holding its power button until the indicator lights start blinking white, then release. When the controller has finished turning on, its LED indicator will change to one of two colors:
  • Green — The controller is above 20% battery charge.
  • Red — The controller has 20% or lower battery charge.
Drone Power and Link Status
Next, ensure the drone and controller are paired by connecting the controller’s USB-A port to the drone's USB-C port.
Once the devices are paired, remove all cables from the drone and controller.
For more information about pairing the controller and drone, go here.
Drone Battery Check
Ensure the drone's battery level is over 20% before flying.
Fully charge the drone's battery by plugging it into a power source using a cable with a USB-C connector, as shown in this animation.
For more information about picking which battery to use, go here.
Install the battery in the drone once charging is complete. Make sure the Up arrow on the battery is facing upward when inserted. This will turn the drone on.
Level Surface Check
A front facing view of the drone sitting atop a level surface with all four landing feet flat on the ground.
If the drone is angled in any way, and not level, the drone will not be able to safely take off. Place the drone in a safe indoor location, and on a level surface to ensure a safe takeoff.
Remember that the Propeller Lock will engage when it detects the drone's movement. See this article for more information.
Additional Safety Checks
Before flying, review the following to ensure the indoor flight area and pilot are fully prepared:
  • Inspect the Drone:
  • Prepare the Indoor Flight Area:
    • Set up a safe indoor area for the drone to fly in. View this article for recommendations.
      • The VEX AIR Drone is intended for indoor use only. Do not fly the drone outside.
    • Ensure at least 5 feet of clear space around the drone in all directions.
    • Make sure there's at least 3 feet of overhead clearance to avoid lights, ceiling fans, or other fixtures.
    • Remove any people, pets, or obstacles from the flight area.
    • Clear away any lightweight or loose items (e.g., paper, plastic cups) that could be blown by the propellers.
  • Get Everyone Ready:
    • Tie back long hair.
    • Keep hands clear of the drone during takeoff and flight.
    • Ensure the pilot(s) know how to activate the emergency stop.
For more detailed information about any of these safety items, go here.
In addition, be sure the Controller is ready for use.
Attach the joysticks by removing them from the back of the controller and screwing them into the joystick holders on the front.
Make sure the lanyard is attached to the controller by screwing the lanyard's pins into the controller.
For more information about assembling the lanyard, go here.
Understand Basic Flight Controls
Before taking flight with the default_fly project, ensure the pilot understands how to control the drone in the air, start a project, and land the drone manually to end a project.
Joystick Flight Controls
The controller has two joysticks that control how the drone can move with its default fly project.
Axis 1 will raise or lower the drone.
Axis 2 will turn the drone left or right.
Axis 3 will move the drone left and right.
Axis 4 will move the drone forward and backward.
Additional Controls
The user screen of the default fly project showing information and button actions. At the top a timer reads 19 seconds, below the current settings show the flight state as off, steering mode as standard, and movement mode as precision. Below, buttons 5 through 12 are labeled, in order as 5 blank, 6 drop payload, 7 show apriltags, 8 show fly off, 9 photo forward, 10 photo downward, 11 reticle on, 12 telemetry on.
The User Screen of the default_fly project shows information and button controls for various settings and actions. Features of this screen include:
  • Timer - View how long the project has been running with the project run timer at the top of the screen.
  • Current Settings - The current flight state, steering mode, and movement mode are shown below the timer.
  • Buttons - Press the on-screen button or the numbered controller button, for each of the listed actions, or to toggle the option on or off.
Taking Off
The controller is shown, powered on, with the takeoff and land button on the lower right hand side highlighted.
To begin a project, press the Takeoff & Land button on the controller.
The controller screen with the programs menu open and the default fly project listed in slot 0. The screen reads Hold Takeoff button to launch.
A menu will appear on the screen showing all current projects loaded on the controller.
Press the project that you want to use. The default_fly project allows you to fly the drone directly with the controller.
Once the project is selected, hold down the Takeoff & Land button until the project slot is filled with the color orange. Then, release the button to begin the project.
Landing
The controller screen with a Mission Summary pop up window in the center. The program flown and Mission duration in minutes and seconds is shown at the top. Along the bottom it reads fly drone to safe location and click land, with a land button beneath.
To land the drone manually, press the Takeoff & Land button while a project is running. A pop-up will appear in the middle of the controller's screen, prompting you to fly to a safe location to land. Pressing Land will stop the project and land the drone.
Once the drone lands, the Mission Summary remains on the screen showing the program that was flown and the mission duration in minutes and seconds. Select Close to close the Mission Summary and end the project.
