Customizing Resources Using Google Drive
Editing or sharing Activities, as well as other resources from the Teacher Portal using Google Drive, can be accomplished in a few easy steps by using ‘Make a copy.’
How to use ‘Make a copy’ for a Google Doc or Google Sheet
Ensure you are logged into your Google account, and open the Google Doc or Google Sheet you would like to edit or share.
For this example, the Basketball Drills VEXcode VR Activity will be used. To learn more about VEXcode VR Activities, view this article.
File menu in a Google doc highlighted in the upper left corner of the Toolbar.
Open the activity and select ‘File.’
Open Google doc File menu with the Make a Copy option highlighted.
Select ‘Make a copy.’
Copy Document options in Google Drive with a text box to type the file name highlighted.
Rename the document if you choose.
The same image with the Folder selection below the file name highlighted.
Select ‘My Drive’ as the folder location and then select ‘OK’ to save a copy of the activity to your Google Drive.
Google doc toolbar of the copied document reads Last edit was seconds ago.
This new copy can use all of your Google Document features, such as editing and sharing.
Prompt reads can't attach this file, with the copy button in the lower right corner highlighted.
Note: Some Classroom Management Systems like Google Classroom will automatically prompt you to make a copy.
Some example resources
Example pacing guide resource showing the same options for copying as other resources.
You can use the procedures above to ‘Make a copy' of many different resources. Some examples include:
Example Email Home for VEXcode VR showing copyable teacher resource examples.
  • Email Home - VEXcode VR: another great example of a resource found in the Teacher Portal. This can save countless hours by having all the pertinent information already created for parents. By using ‘Make a copy,’ you can customize it for each class!
For more information about the educator resources provided to support VEXcode VR, view this article.
