Using the VEX Classroom App with the Coder
The VEX Classroom app is a useful tool that allows users to get started quickly.
Navigate to your device’s app store and search for ‘VEX Classroom’ to download the app if you have not already done so.
Note: the VEX Classroom app is available on the following platforms:
Updating the Coder Firmware
VEX Classroom App screen with Update All, Rename All buttons and a list of detected Coders underneath. All the Coders are colored orange.
The firmware on one or multiple Coders can be updated using the VEX Classroom app.
For more information on how to update one or multiple Coders using the VEX Classroom app, view the Update the Coder Using the VEX Classroom App article.
Renaming a Coder
Coder 4 called out in a list of Coders connected to the Classroom App.
To rename a single Coder, select the Coder that is to be renamed.
Coder number 4 selected with the rename button on the bottom left called out.
Select ‘Rename.’
The New Device Name field ready to receive a new name.
Enter the new name of the Coder. Note that only letters, numbers, and spaces are accepted.
Device Name Screen in the Classroom App with the Save Name button called out in the lower left corner.
Once finished, select Save Name.
Coder with the name Apple displayed.
The new name will then display.
Locating a Coder
A Coder can be located using the app. The location feature identifies a specific Coder by making the indicator light on the Coder flash yellow.
The Locate button to the right of a Coder in the app.
To locate a Coder, select the Locate button beside the Coder that is to be located, and look for the Coder with the light flashing yellow.
Monitoring Battery Life
2 Coders listed in the app with a battery icon reading 75% called out to the right.
The state of each Coder’s Battery is listed. This can be used to monitor the Battery life of one or more Coder’s within range.
Viewing Coder Cards
Coder Cards currently in the Coder can be viewed in the Classroom App.
The Read Cards button highlighted in the Coder's device info screen.
Select Read Cards on the Coder's Device Info screen.
Coder Cards displayed in the Coder's Device Info.
All the Coder Cards currently inserted in the Coder will be displayed.
To learn more how to troubleshoot your Coder using the VEX Classroom App, see this article.
