Using Example Blocks Projects in VEXcode VR
Example projects are a great resource if you are just getting started with VEXcode VR. They allow you to observe how different blocks in VEXcode VR are used.
Using Blocks Example Projects
Example Projects menu showing block-based project templates for VEXcode VR
To open an Example Project, select the File menu.
Example Blocks project open in the VEXcode VR workspace
Choose ‘Open Examples.’
Example Blocks project open in VEXcode VR with the Playground visible
Icons for many different Example Projects will be shown. Each icon represents a different project and are colored according to the block categories.
Example Blocks project open in VEXcode VR with the Playground visible for testing
The Filter bar can be used to quickly find a specific type of example.
Example Blocks project open in VEXcode VR with the Playground ready to start
To open any example, select one from the menu.
VEXcode VR Example Blocks project showing block categories and a sample robot program
Blocks for the example base project will populate in the Workspace. These blocks and their parameters can be changed or removed. Additional blocks can be added to modify the example project.
Starting an Example Project in the Playground
Example Blocks project open in VEXcode VR with the Playground ready to run
Select the Playground icon in the Toolbar to launch the Playground.
Example Blocks project open in VEXcode VR with the block workspace and VR Playground displayed
Select ‘Start’ in the Toolbar.
Note: selecting ‘Start’ from the Toolbar will launch the Playground if it is not already opened.
Start button to run the example project in VEXcode VR
Or, select the ‘Start’ icon on the Playground window.
VEXcode VR workspace with the Example Projects menu open and a blocks project loaded
Be sure to save the project to your device if you want to change or revisit the project at a later time.
Notes in Blocks Example Projects
Menu of example block projects available in VEXcode VR
Each Blocks Example Project contains a note in the Workspace.
Example Blocks menu showing available project categories in VEXcode VR
In a Blocks Example Project, the note provides a short summary for what the project does and the recommended Playground.
Notes can be used to document certain information in a project. For more information on notes, view this article from the VEX Library.
