Using Notes in a VEXcode VR Blocks Project
Here are some basic ways to manage notes in projects.
Adding a Note to a Project
Add Note option in the File menu of a VEXcode VR Blocks project
Right-click or long-press anywhere in the Workspace and select 'Add Note.'
Notes attached to blocks in a VEXcode VR project workspace
Then, type any text, numbers, or symbols into the note.
  • Press the 'Enter' or 'Return' key to write a multi-line note.
  • Select anywhere in the Workspace when the note is complete.
Collapsing Notes
Open Notes button in VEXcode VR
You can collapse a note by selecting the down arrow in the top margin.
Collapsed note attached to a block in the VEXcode VR workspace
This will collapse the note.
Moving Notes Around
Notes panel displayed beside the Blocks workspace in a VEXcode VR project
You can move a note by selecting the top margin and dragging it around.
Deleting Notes
Delete note confirmation dialog with Delete and Cancel buttons
You can delete any note by selecting the 'X' located at the top right of the note.
Menu for deleting notes, comments, or blocks in a VEXcode VR project
You can also delete a note by right-clicking or long-pressing on it and selecting 'Delete.'
Duplicating Notes
Block context menu with Duplicate selected to copy a Note block in VEXcode VR Blocks
You can duplicate a note by right-clicking or long-pressing on it and selecting 'Duplicate.'
