Connecting with App-based VEXcode GO on Android
To begin connecting your GO Brain to VEXcode GO, first install and open the VEXcode GO application. Then, follow the steps below to complete the connection between your GO Brain and VEXcode GO.
Connect a VEX GO Brain to VEXcode GO
GO Battery with its connection cable plugged into the Battery Port on a GO Brain.
Connect the GO Brain to the Battery.
Diagram of a hand pressing down on the Brain's power button to turn it on. The button will glow green when it is turned on.
Turn on the GO Brain by pressing the button in the center.
VEXcode GO with the Brain icon on the Toolbar highlighted.
Open VEXcode GO and select the Brain icon in the Toolbar.
VEXcode GO with the Brain dropdown menu opened and the Connect button highlighted.
Select Connect.
VEXcode GO with a dialogue box opened to select the GO Brain to connect to. Two Brains are listed, and the first Brain in the list is highlighted.
A list of available GO Brains will appear. Select the name of the Brain you want to connect to.
VEXcode GO with a dialogue box opened to select the GO Brain to connect to. The first Brain in the list has been selected, and the Connect button below is highlighted.
Once a Brain is chosen, select the Connect button.
VEXcode GO with an orange Brain icon on the Toolbar to indicate that it is connecting.
The Brain icon will turn orange and a Connecting message will appear while the Brain is connecting.
VEXcode GO with a green Brain icon on the Toolbar to indicate that the Brain has connected.
Once the VEX GO Brain is connected the Brain icon will turn green. The message in the window will say Connected to: and list the name of the VEX GO Brain that is connected.
VEXcode GO with a connected Brain and the Brain dropdown menu opened. The battery indicator icon is highlighted.
Underneath the Connected to: message, there is an icon that displays the battery level of the GO Brain.
Red battery icon indicating a low battery.
Yellow battery icon indicating a medium battery.
Green battery icon indicating a full battery.
The battery indicator displays one of three colors to show the current charge level.
  • Red - Low battery.
  • Yellow - Medium battery.
  • Green - Full battery.
Disconnect a VEX GO Brain from VEXcode GO
VEXcode GO with a connected Brain and the Brain dropdown menu opened. The Disconnect button is highlighted.
Select Disconnect to disconnect your GO Brain from VEXcode GO.
If You Are Experiencing Connection Issues
