Starting, Downloading, and Running a Python Project in VEXcode V5
Starting and downloading Python projects in VEXcode V5 is easy.
How to Start a Python Project
New Blocks project opened in VEXcode V5.
Launch VEXcode V5. The platform defaults to the Blocks interface.
VEXcode V5 Toolbar with the File menu open and the New Text Project option highlighted. New Text Project is the second option in the menu, below New Blocks Project.
Select ‘File,’ then ‘New Text Project’ to open the text interface.
VEXcode V5 Select a Project Language prompt that has options for Python or C++. Either language can be selected to open a new project, or below there is a Cancel button that will close the menu. The Python project option is highlighted.
Next, select the Python project language. There is the option to start a new project in either C++ or Python.
New Python project opened in VEXcode V5.
The Python interface will open.
How to Build a Python Project
This section will show you how to create a basic Python project using commands from the Tool Box. The project outlined here will drive the V5 Clawbot forward for 200 millimeters (mm).
VEXcode V5 Toolbar with the File menu open and the Open Examples option highlighted. Open Examples is the fifth option in the menu, below New Blocks Project, New Text Project, Open, and Open Recent.
Select ‘File’ then ‘Open Examples” to open a template project.
Thumbnail image for the Clawbot (Drivetrain 2-motor, No Gyro) example project.
Select the Clawbot (Drivetrain 2-motor, No Gyro) template. Templates are blank projects with preset device configurations.
VEXcode V5 with a template Example Project opened, including configured devices and code comments with a description of the project.
Notice that a set of project comments open in the workspace. You will add commands after the comments.
To learn more about comments, see the Using Comments in VEXcode V5 Python article here.
VEXcode V5 with the Clawbot (Drivetrain, 2-motor, No Gyro) template Example Project opened. A specific blank line of code at line 15 is highlighted directly below the comment that reads Begin project code.
Select enter at the end of the last line of code (line 14). This should create the next numbered line (line 15). This is where you will start adding code to the project.
VEXcode V5 with the Drive for command highlighted in the Python Toolbox.
Now you can add commands from the Tool Box. Select the drive_for command.
VEXcode V5 with the Clawbot (Drivetrain, 2-motor, No Gyro) template Example Project opened. The previously blank line of code now has a Drive for command in it that reads drivetrain.drive_for(FORWARD, 200, MM).
Drag the drive_for command into the workspace and place it on the last line of the project (line 15).
How to Download and Run a Python Project
VEXcode V5 Toolbar with the project name field highlighted and renamed to Drive Forward. To the right of the project name a label reads Saved.
First, name and save your Python project. View one of the following articles for detailed information on how to save a VEXcode V5 Python project:
VEXcode V5 with the Slots dropdown menu opened. There are 8 available slots for downloading projects to the Brain, and the first slot is highlighted.
Then, choose which of the Brain’s slots you will download the project to. To do this, select the ‘Slot’ button on the Toolbar.
VEXcode V5 Toolbar with the green Brain icon highlighted, indicating that the Brain is connected.
Next, connect the Brain to your device (Directly via Micro-USB or via VEX Controller) and check that the Brain icon is green.
VEXcode V5 Toolbar with the Download icon highlighted in between the Brain and Run icons.
Select the ‘Download’ button to download the project to the Brain. The project will download to the chosen slot.
VEXcode V5 Toolbar with the Run icon highlighted in between the Download and Stop icons.
Finally, select ‘Run’ to start the project while the robot is still connected to your computer.
V5 Brain screen is shown in a user program's menu. The Run button is highlighted, and the program's name reads Drive Forward.
Or, disconnect the Brain from your device and run the project on the V5 Brain.
