When working in VEXcode V5, it is important to understand how to save a project on a Chromebook.
Using ‘Save’
Project
Saving VEXcode V5 Python projects is easy. First, select the project name window.
VEXcode
A Save dialog window will open.
Drive
Name your project by typing in your device's Save dialog window.
Notice the .v5python file extension after the file name. All VEXcode V5 Python files will have this file extension.
Drive
Select the destination, such as the Downloads folder.
Save
Then select ‘Save.’
My file download
The file will save to the chosen destination on your device. All VEXcode V5 Python projects are recognizable by their .v5python extension.
Drive forward
The updated project name will be visible in the project name window.
Autosave
Once a project is saved, VEXcode V5 will automatically save all changes in a project.
Note: Whenever there is an unsaved project VEXcode V5 will prompt users to save their work if the user attempts to:
  • Close VEXcode V5
  • Create a new project
  • Open another project
Using ‘Save As’
File
You can also use the ‘Save As’ option from the File menu to make a copy of a project under a different name or in a different location.
