Editing or sharing VEXcode VR Activities, as well as other resources from the Teacher Portal using Google Drive, can be accomplished in a few easy steps by using ‘Make a copy.’
The following article will cover:
- How to use ‘Make a copy’ for a VEXcode VR Google Doc or Google Sheet
- Some example resources
Ensure you are logged into your Google account, and open the Google Doc or Google Sheet you would like to edit or share.
For this example, the Basketball Drills VEXcode VR Activity will be used. To learn more about VEXcode VR Activities, view this article.
Open the activity and select ‘File.’
Select ‘Make a copy.’
Rename the document if you choose.
Select ‘My Drive’ as the folder location and then select ‘OK’ to save a copy of the activity to your Google Drive.
This new copy can use all of your Google Document features, such as editing and sharing.
Note: Some Classroom Management Systems like Google Classroom will automatically prompt you to make a copy.
You can use the procedures above to ‘Make a copy' of many different resources. Some examples include:
- VEXcode VR Cumulative Pacing Guide: one of the many resources available through the Teacher Portal. The portal requires you to register if you do not have a VEX account. By using ‘Make a copy,’ the Pacing Guide can be easily shared and edited to fit the needs of you and your students.
- Email Home - VEXcode VR: another great example of a resource found in the Teacher Portal. This can save countless hours by having all the pertinent information already created for parents. By using ‘Make a copy,’ you can customize it for each class!
For more information about the educator resources provided to support VEXcode VR, view this article.
