Controller Buttons / Joysticks - Blocks Tutorials
VEXcode V5 Blocks can access all of the data from the V5 Controller by referencing the buttons and axes by their described names.
This article will cover the following:
  • Position and Names of Buttons and Joysticks
  • Blocks that include Controller Buttons and Joysticks
  • Additional Controller Articles
View the following image describing the position of the Buttons and Joysticks as well as their proper names:
Buttons return values of:
  • 1 - Pressed
  • 0 - Not Pressed / Released
The Joystick Axis return values of -100 to +100 when centered at zero.
When programming in VEXcode V5 Blocks, understanding the Button and Joystick names as well as their position on the Controller helps determine which block should be used. The Controller will first need to be configured before blocks including the Controller will be visible. Click here for more information about blocks:
For more information about using the Controller, view the following articles:
