Using Help in VEXcode V5
Help explains what a block does so that you can figure out if it’s helpful for your project.
Select the Help icon. It’s at the top right of the interface and has a question mark in it.
You will see a blank screen extend from the right until you select a block to learn about.
Select any blocks that you want to learn more about.
Hide the Help menu when finished by pressing the right arrow next to the Help icon.
