Installing or Removing the VEX IQ Brain Battery
Before installing, you should have a charged VEX IQ Battery.
Note: Images in this article show a (1st generation) Brain, follow the same steps for installing a Battery into a (2nd generation) Brain.
Install the Battery
Slide the Battery into the VEX IQ Brain and listen for a click that indicates the Battery has been inserted correctly and completely.
Remove the Battery
Squeeze the latch at the end of the Battery and pull it out of the Brain.
NOTE: Pushing on the Battery from the other end helps in removing it.
NOTE: The Battery should always be removed from the Brain if it is going to be stored for longer than two weeks.
