Using VEX IQ (2nd generation)? See this article.
Notice there are two different indicator lights on the Controller. The first indicator light is called the Power / Radio Link LED.
There are two possible colors of the Power / Radio Link LED to indicate the status of the VEX IQ Controller Battery and of the VEX IQ Radio Link:
| Power / Radio Link LED Color | Status | |
Solid Green | Controller ON - Controller Battery level sufficient - with NO Radio Link (searching) |
Blinking Green | Controller ON - Controller Battery level sufficient - with good Radio Link. |
Solid Red | Controller Battery level low - with No Radio Link |
Blinking Red | Controller Battery level low - with good Radio Link |
If the Controller’s LED is not blinking, the Controller is not wirelessly connected to the VEX IQ Robot Brain. Connecting with the Tether Cable overrides the wireless connection and the Controller’s LED will show solid green. Click here for instructions for properly linking (wirelessly connecting) the Controller with the Brain.
The second is called the Charge LED.
There are three possible colors for the Charge LED: green, red, and gray.
| Charge LED Color | Status | |
Solid Green | Controller Battery is completely charged |
Solid Red | Controller Battery charge in progress |
Blinking Red | Controller Battery fault |
Off | Not charging |
Click here for instructions for charging the Controller Battery.
Indicator Lights when Wirelessly Connecting
When wirelessly connecting a VEX IQ Controller to the VEX IQ Robot Brain, the indicator lights on the front of both the Controller and the Brain may display different colors. The different lights and flashing patterns indicate the status of the Brain’s and Controller’s connectivity and power.
Use this checklist when testing connectivity and understanding indicator lights:
- Is the Power/Link LED on the Controller and the Brain LED both solid green?
- If the answer is Yes, then the devices are charged but not paired.
Follow the instructions in How to Pair the VEX IQ Robot Brain with the VEX IQ Controller for Wireless Operation.
- Is the Power/Link LED on the Controller and the Brain LED both blinking green?
- If yes, then success! Both LEDs should blink green when wirelessly connected.
It indicates that there is a good connection and both batteries are charged.
- Is one or both of the LEDs red or blinking red?
- If the answer is Yes and the Controller’s LED is red, then the Controller Battery is low.
Follow the instructions in How to Charge the VEX IQ Controller Battery.
- If the answer is Yes and the Brain’s LED is red, then the Robot Battery is low.
Follow the instructions in How to Charge the VEX IQ Robot Battery.
If the wireless pairing is still unsuccessful, be sure that the VEX IQ Radios in the Brain and Controller are a matching pair. Review the following:
- How to Identify VEX IQ Radios
- How to Install and Remove VEX IQ Radios in Brain and/or Controller
