VEXcode EXP 4.0 introduces a range of new features. This major update focuses on enhancing productivity and accessibility in robotics coding. Read below to learn what new features are available with VEXcode EXP 4.0!
Go here to download the new installer for VEXcode EXP 4.0!
CTE Workcell
VEXcode EXP now fully supports the CTE Workcell. The CTE Workcell introduces students to the world of industrial robotics and automation through hands-on activities. View the animation below to see an example of a project built with the CTE Workcell using conveyor belts, the 6-Axis Robotic Arm, and various sensors.
In VEXcode EXP, the 6-Axis Robotic Arm can be directly connected to a computer without an EXP Brain to access the Teach Pendant.
Teach pendants are devices used to control and program robotic arms and other machinery for industrial automation and include buttons or a touch screen that allow operators to manually guide a robot's movements.
Connecting the 6-Axis Robotic Arm to an EXP Brain will also allow you to integrate new devices into your CTE project like the CTE Pneumatics system, Signal Tower, and Object Sensor.
Go here to learn more about the CTE Workcell and using it in classrooms.
Switch Blocks
New Switch Blocks are now available, making the transition from block-based coding to text-based programming seamless.
Drag and Drop Switch Blocks: All Switch Blocks are available to be dragged from the toolbox and typed into directly.
Type Python Directly Into Blocks Projects: VEXcode allows you to incorporate Python commands directly into your projects, integrating them seamlessly with other Blocks. To assist you in writing correct code, VEXcode also provides an autocomplete feature for Python commands.
Code Conversion: Convert entire block stacks to Python with a single click.
This feature is perfect for learners looking to graduate from blocks to text. For more information about coding with Switch Blocks, go here.
Save and Load in Web-based VEXcode
Other changes to the File Menu:
- Load From Your Device has now been changed to Open.
- Save to Your Device has now been changed to Save as.
- You can also now manually save using the Save button.
For a step-by-step guide on how to load and save VEXcode EXP Project on a Chrome Browser, go here.
Updated AI Vision Sensor Detection
The AI Vision Sensor is now able detect AprilTags and AI Classifications.
AprilTags are images that can be detected and have unique IDs. They can be printed out and used in fields for use with robots. Download a printable AprilTag PDF here.
The AI Vision Sensor can also identify different colored buckyballs and rings from the VEX EXP Classroom Bundles.
Go here to learn about how to use the AI Vision Sensor in Blocks, Python, and C++.
Read Blocks Aloud
All Blocks inside VEXcode EXP 4.0 can now be read aloud with a simple right-click.
This feature is available on all devices but Android.
- Customizable Voices: Choose from various voices and adjust speed and pitch in the new Tools Menu.
- Context Menu Integration: Right-click any block to hear it read aloud.
Go here for step-by-step instructions on how to use the Read Feature in VEXcode.
Tools Menu
VEXcode EXP 4.0's new Tools Menu is packed with features for productivity and accessibility.
Keyboard Shortcuts
There are new Keyboard shortcuts available for starting, stopping, and opening help documentation.
| Mac | Windows |
High Contrast Theme
High contrast themes increase the distinction between text and background, making content easier to read for users with low vision, color blindness, or other visual impairments.
| Default | High Contrast |
Speech Settings
Working with the new Read Blocks feature, you can change the voice used, the speed of speech, and the pitch from this menu.
API Documentation
Access comprehensive API documentation, making it easier than ever to explore and utilize the full potential of your VEX EXP robot.
Click here to access the official VEX API Reference site.
Web-based Wireless Project Downloads
Web-based VEXcode EXP is now able to wirelessly connect to an EXP Brain through an EXP Controller.
To learn how to wirelessly download a project to your EXP Brain, go here.
