Connecting a 6-Axis Robotic Arm to Web-Based VEXcode EXP – Chromebook
To connect a 6-Axis Robotic Arm to VEXcode EXP, you must first power on your 6-Axis Arm, and directly connect the 6-Axis Arm to your computer.
Blank Arm blocks project has been opened in the VEXcode EXP workspace.
Open VEXcode EXP and open a new Arm project.
VEXcode EXP with the 6-Axis Arm icon highlighted on the Toolbar.
The 6-Axis Arm icon in the top right of the screen will be white, showing that no 6-Axis Robotic Arm is currently connected. Select this icon.
VEXcode EXP with the 6-Axis Arm dropdown menu opened and the Connect Arm button highlighted.
When selected, a new window will open. Select Connect Arm to start connecting your 6-Axis Robotic Arm to VEXcode EXP.
VEXcode EXP Browser connection prompt that reads Your browser will now attempt to connect to your 6-Axis Arm. Below, the Continue button is highlighted.
Select Continue.
Browser connection window with two options listed, one reads ACM0, and the other reads ACM1. The option reading ACM0 is highlighted.
Select the port that has the smallest number. In this screenshot, 0 is smaller than 1, so it is selected.
Browser connection window with the ACM0 option selected and the Connect button highlighted below.
Once the correct port is highlighted, select Connect to finish connecting the 6-Axis Robotic Arm.
VEXcode EXP Toolbar with a green 6-Axis Arm icon, indicating that the Arm has been successfully connected.
The 6-Axis Arm icon will turn green, this indicates that the 6-Axis Robotic Arm is successfully connected and its firmware is up to date.
VEXcode EXP Toolbar with an orange 6-Axis Arm icon, indicating that the Arm is connected but its firmware is out of date.
If the 6-Axis Arm icon is orange, that means the firmware is out of date. Read this article to learn how to update your 6-Axis Robotic Arm's firmware.
