Coding with the AI Vision Sensor in VEXcode V5 Python
Make sure you have Color Signatures and Color Codes configured with your AI Vision Sensor so they can be used with your blocks. To learn more about how to configure them, you can read the articles below:
The AI Vision Sensor can also detect AI Classifications and AprilTags. To learn how to enable these detection modes, go here:
To learn more detail about these individual commands and how to use them in VEXcode, go to the API site.
Obtain Visual Data with the AI Vision Sensor
Every AI Vision Sensor command will start with the name of the configured AI Vision Sensor. For all the examples in this article, the name of the AI Vision Sensor used will be ai_vision_1.
take_snapshot
The take_snapshot method takes a picture of what the AI Vision Sensor is currently seeing and pulls data from that snapshot that can then be used in a project. When a snapshot is taken, you need to specify what type of object the AI Vision Sensor should collect data of:
  • A Color Signature or Color Code
    • These Visual Signatures start with the name of the AI Vision Sensor, double underscore, and then the name of the Visual Signature, for example: ai_vision_1__Blue.
  • AI Classifications - AiVision.ALL_AIOBJS
  • AprilTags - AiVision.ALL_TAGS
Taking a snapshot will create a tuple of all of the detected objects that you specified. For instance, if you wanted to detect a "Blue" Color Signature, and the AI Vision Sensor detected 3 different blue objects, data from all three would be put in the tuple.
In this example, the variable vision_objects stores a tuple containing the detected "Purple" Color Signatures from the AI Vision Sensor named ai_vision_1. It displays the number of objects detected and captures a new snapshot every 0.5 seconds.
while True:
    # Get a snapshot of all Purple Color Signatures and store it in vision_objects.
    vision_objects = ai_vision_1.take_snapshot(ai_vision_1__Purple)
    # Check to make sure an object was detected in the snapshot before pulling data.
    if vision_objects[0].exists == True
        brain.screen.clear_screen()
        brain.screen.set_cursor(1, 1)
        brain.screen.print("Object count:", len(vision_objects))
    wait(0.5, SECONDS)
Object Properties
Every object from a snapshot has different properties that can be used to report information about that object. The available properties are as follows:
  • id
  • centerX and centerY
  • originX and originY
  • width
  • height
  • angle
  • score
  • exists
To access an object's property, use the variable name storing the tuple, followed by the object index.
The object index indicates which specific object's property you want to retrieve. After taking a snapshot, the AI Vision Sensor automatically sorts objects by size. The largest object is assigned index 0, with smaller objects receiving higher index numbers.
For example, calling the largest's object's width inside the vision_objects variable would be: vision_objects[0].width.
id
The id property is only available for AprilTags and AI Classifications.
Three square identification markers labeled with IDs 0, 9, and 3, each with corresponding coordinates and size measurements displayed in white text. ID 0 is on the left, ID 9 is on the right, and ID 3 is at the bottom center. Each marker has a unique black-and-white pattern inside a square.
For an AprilTag, the id property represents the detected AprilTag(s) ID number.
Identifying specific AprilTags allows for selective navigation. You can program your robot to move towards certain tags while ignoring others, effectively using them as signposts for automated navigation.
Two balls and two rings identified in the image, with labels indicating their position, size, and score. The red ball is on the left, the blue ball is on the right, the green ring is at the bottom left, and the red ring is at the bottom right. Each object is outlined with a white box, and details such as X, Y coordinates, width, height, and a score of 99% are displayed in white text.
For AI Classifications, the id property represents the specific type of AI Classification detected.
Identifying specific AI Classifications allows the robot to only focus on specific objects, such as only wanting to navigate towards a red Buckyball, not a blue one.
Go to these articles for more information on AprilTags and AI Classifications and how to enable their detection in the AI Vision Utility.
centerX and centerY
This is the center coordinates of the detected object in pixels.
A blue Buckyball being tracked by a computer vision system. The object is outlined with a white square, and inside the outline is a smaller red square surrounding a centered white cross. In the top-left corner of the image, a label indicates the object is blue, with coordinates X:176, Y:117, and dimensions W:80, H:78.
CenterX and CenterY coordinates help with navigation and positioning. The AI Vision Sensor has a resolution of 320 x 240 pixels.
Two blue cubic objects tracked by a vision system. The upper object is labeled with coordinates X:215, Y:70, and dimensions W:73, H:84, with a white outline and a centered white cross. The lower object is labeled with coordinates X:188, Y:184, and dimensions W:144, H:113, also outlined in white with a centered white cross.
You can see that an object closer to the AI Vision Sensor will have a lower CenterY coordinate than an object that is farther away.
In this example, because the center of the AI Vision Sensor's view is (160, 120), the robot will turn right until a detected object's centerX coordinate is greater than 150 pixels, but less than 170 pixels.
while True:
    # Get a snapshot of all Blue Color Signatures and store it in vision_objects.
    vision_objects = ai_vision_1.take_snapshot(ai_vision_1__Blue)
        # Check if the object isn't in the center of the AI Vision Sensor's view.
        if vision_objects[0].centerX > 150 and 170 > vision_objects[0].centerX:
            # Keep turning right until the object is in the center of the view.
            drivetrain.turn(RIGHT)
        else:
            drivetrain.stop()
    wait(5, MSEC)
originX and originY
OriginX and OriginY is the coordinate at the top-left corner of the detected object in pixels.
A blue Buckyball being tracked by a vision system. A white outline surrounds the object, with a centered white cross inside the outline. The top-left label indicates the object's color as blue, along with coordinates X:176, Y:117, and dimensions W:80, H:78. A small red square highlights the object's top-left corner.
OriginX and OriginY coordinates help with navigation and positioning. By combining this coordinate with the object's Width and Height, you can determine the size of the object's bounding box. This can help with tracking moving objects or navigating between objects.
width and height
This is the width or height of the detected object in pixels.
The image shows a blue Buckyball with a white square outline tracking it. The top left corner has a label indicating it is a blue object, with coordinates X:176, Y:117, and dimensions W:80, H:78. Red arrows highlight the width and height of the object.
The width and height measurements help identify different objects. For example, a Buckyball will have a larger height than a Ring.
Two blue cubic objects being tracked by a visual recognition system. The upper cube has a white outline with a label indicating its position as X:215, Y:70 and dimensions W:73, H:84. The lower cube has a similar white outline with the label displaying X:188, Y:184 and dimensions W:144, H:113. Each cube has a centered white cross, likely indicating the focal point for tracking. The labels highlight the measurements and tracking data for each object.
Width and height also indicate an object's distance from the AI Vision Sensor. Smaller measurements usually mean the object is farther away, while larger measurements suggest it's closer.
In this example, the width of the object is used for navigation. The robot will approach the object until the width has reached a specific size before stopping.
while True:
        # Check if the largest object is close to the AI Vision Sensor by measuring its width.
        if vision_objects[0].width < 250:
            # Drive closer to the object until it's wider than 250 pixels.
            drivetrain.drive(FORWARD)
        else:
            drivetrain.stop()
    wait(5, MSEC)
angle
A rotating gif showing red and green blocks. When the blocks are positioned perfectly horizontal from red to green, they are shown to be 0 degrees. If the red block is on top of the green block vertically, it is at 90 degrees. If the blocks are horizontally green to red, it is 180 degrees. If the green block is on top of the red block vertically, it is 270 degrees.
The angle property is only available for Color Codes and AprilTags.
This represents if the detected Color Code or AprilTag is orientated differently.
A stack of two cubes, one green on top and one blue on the bottom, being tracked by a vision system. A white outline surrounds both cubes, with a white cross centered on the green cube. The label at the bottom of the image displays Green_Blue A:87°, indicating the detected colors and an angle measurement. Below that, the coordinates are listed as X:117, Y:186, with dimensions W:137, H:172, representing the position and size of the stacked cubes in the frame.
You can see if the robot is orientated differently in relation to the Color Code or AprilTag and make navigation decisions according to that.
Two cubes, one green and one blue, placed side by side and tracked by a vision system. A white outline surrounds both cubes with a white cross at the center. The top-left label indicates Green_Blue A:0°, referencing the detected colors and an angle measurement. Below that, the coordinates are shown as X:150, Y:102, with dimensions W:179, H:109, representing the position and size of the cubes within the frame.
For instance, if a Color Code isn't detected at a proper angle, then the object it represents may not be able to be picked up properly by the robot.
score
The score property is used when detecting AI Classifications with the AI Vision Sensor.
The image shows four objects being tracked by a vision system: two balls and two rings. The red ball is labeled with coordinates X:122, Y:84, W:67, H:66, and a score of 99%. The blue ball has X:228, Y:86, W:70, H:68, with a score of 99%. The green ring has coordinates X:109, Y:186, W:98, H:92, and a score of 99%. The red ring is labeled X:259, Y:187, W:89, H:91, with a score of 99%. Each object is outlined in white, indicating tracking accuracy.
The confidence score indicates how certain the AI Vision Sensor is about its detection. In this image, it's 99% confident in identifying these four objects' AI Classifications. You can use this score to ensure your robot only focuses on highly confident detections.
exists
The exists property is used to detect if a specified Visual Signature has been detected in the last taken snapshot.
This lets you check if any detected objects were detected in the previous snapshot. This property will return a True when an object exists, and a False when the object does not exist.
