Accessing VEXcode VR Switch
VEXcode VR Switch is available to help with the transition from block-based to text-based coding. With VEXcode VR Switch, users can convert blocks to Switch Python blocks or use a Switch block to immediately begin typing Python commands.
To access VEXcode VR Switch, you must have a VEXcode VR Premium license. See this site for more information about the Premium license and to purchase.
To access Switch Blocks in VEXcode VR, follow the steps below:
VEXcode VR Switch interface with block-based coding workspace and virtual robot playground
Go to vr.vex.com and select Login Here > if it's your first time to the VEXcode VR site.
VEXcode VR Switch workspace with block coding area and robot controls
Enter your Class Code and select Submit.
VEXcode VR Switch interface with options to open Blocks or Python projects
Switch Blocks will now be available in the Toolbox for your VEXcode VR projects.
