The Print Console allows the user to display messages, report sensor values, or to present data from VEXcode EXP projects. The Print Console also allows users to save print outputs as a text file.
The Print Console can also be used to display process information, providing visual cues that enable the user to see what is happening in a VEXcode EXP project at a specific moment in time, thereby making a visual connection between the project and the actions of the EXP Robot.
The Print Console needs to have active communication between the VEX EXP Brain and the device being used with VEXcode EXP. This can be accomplished by:
USB Connection
Wireless Via Controller
Note: Bluetooth communication is unavailable.
How to Open the Print Console
The Print Console is located in the EXP Monitor Display. To open the Print Console, select the Monitor Display icon next to Help.
The Monitor Display will open once selected. The Print Console is at the right side.
How to Use the Print Console in a Project
Look and Draw Blocks that Trigger the Print Console
Specialized Look blocks are used within a VEXcode EXP project in order to trigger the Print Console. These blocks print words, numbers, reported values from variables, a calculation of an operator, or values reported from a sensor or device.
The Help feature in VEXcode EXP provides additional information on these and other programming blocks. See this article for information on how to access the Help feature.
The [Set pen color] block under the Draw category can also be used in the Print Console by selecting "Console" from the dropdown menu.
Applying Look Blocks with the Print Console
Use the Look blocks within a project to print a message, or display data in the Print Console.
To use the Print blocks, select the desired Look block and add it to a project. Select "Console" from the dropdown menu.
Note: The 'and set cursor to next row' portion of the block must be enabled for text to appear in the Print Console.
Download the project to the EXP Robot Brain and Select "Run".
See this article on downloading and running a project.
Once “Run” is selected, the project will run and the colored text or programmed values will be printed to the Print Console as dictated by the VEXcode EXP project.
Applying Draw Blocks with the Print Console
Use the Draw blocks within a project to change the text color in the Print Console.
To use the [Set pen color] block, select the [Set pen color] block and add it to a project.
Note: The [Set pen color] block is the only Draw block that can be used in the console.
See this article on downloading and running a blocks project.
Clear Rows in the Print Console
There are two ways to clear all information from the Print Console. The first way to completely clear all text is to select the “Clear” button on the bottom left of the Print Console.
Another way to clear the Print Console is to use the [Clear all rows] block.
Add the [Clear all rows] block to a project in order to remove all of the lines in the Print Console.
In this project, “Hello” will print on the Print Console. After 3 seconds, all rows will be cleared. Then, “Goodbye” will be printed on the Print Console and clear after 3 seconds.
Save from the Print Console
It is easy to save information from the Print Console onto your device. Select “Save” on the bottom of the Print Console to save all text as a .txt file.
Once you select the “Save” button, the file will automatically save to the Downloads folder on your device as a .txt file.
Note: The file does not save the printed colors.
Example Projects Using the Print Console
Report Variable Values and Data in a Project
The Print Console can be used to report variable values at discrete moments within a project.
Use the Print Console to print the value of “myVariable."
In the project on the left, the Print Console displays variable values when the Brain buttons are pressed. The variable increases when the 'left' button is pressed, and decreases when the 'right' button is pressed.
Report Sensing Values and Data in a Project
The Print Console can be used to to report sensor data at discrete moments within a project.
The data captured by the Print Console allows the user to see valuable information about project processes including EXP Robot sensor information. When the [Print] block is triggered, it can be programmed to display information captured in the moment.
In the project on the left, the Print Console displays information reported by the Inertial Sensor built into the EXP Brain as prescribed by the Look and Sensing blocks within the project. This information includes changes that the Inertial Sensor captures at discrete moments while the project is running: time in seconds and the rotation of the BaseBot in degrees.
Note: The project in this example uses the BaseBot (Drivetrain, 2-motor) template.
