Accessing Help in a VEXcode EXP Blocks Project
Help explains what a block does so that you can figure out if it’s helpful for your project.
VEXcode EXP Toolbar with the Help icon highlighted to the right of the Monitor icon.
Select the Help icon. It’s at the top right of the interface and has a question mark in it.
VEXcode EXP with the Help menu opened and no block selected. The Help menu has a message that reads 'Select a block to see more information'.
You will see a blank screen extend from the right until you select a block to learn about.
VEXcode EXP blocks Toolbox with the Spin block shown and selected. The Help menu is opened to the side and the Spin block is described in the menu. Descriptions of the block and how it can be used are shown along with images of example uses.
Select any blocks that you want to learn more about.
VEXcode EXP with the Help menu opened and the Close Menu arrow in the top right corner highlighted.
Hide the Help menu when finished by pressing the right arrow next to the Help icon.
