The VEX Digital Coder app was designed with accessibility in mind. The Digital Coder ensures that all students can access the same level of coding capability by offering more than one way to see, hear, and interact with Coder projects. This article explains each of these features and how to use them, so every student has the tools they need to build, run, and debug their own projects.
Accessibility Mode
The Digital Coder uses colored lights to show students what is happening in a project. Accessibility mode adds symbols, words, and sound to that information, so students can build and debug whether or not they can tell the colors apart. Any student can turn it on, and every student uses the same app and the same steps.
Turn On Accessibility Mode
Select the Settings button.
Select Accessibility mode to turn it on.
Select × to close the Settings window.
Darker Card Colors
With Accessibility mode on, cards use darker colors that are easier to read. The right column shows the darker colors.
Lights with Symbols
In Accessibility mode, each light shows a symbol as well as a color, so students don't have to rely on color alone to get information about their project from the Coder.
For example, a checkmark symbol appears alongside the green light to show which Coder card the robot is currently running. The same checkmark symbol is added to the flashing green light to show that the Coder is connected to the robot.
When stepping through a project, an exclamation point symbol appears alongside the yellow light to show the card that will run the next time you select Step.
A red light with an × means the project can’t run. Here, slot 1 is empty.
Error Messages
With Accessibility mode on, an error message explains what needs to be fixed, helping students to understand how to debug their projects.
When a light turns red, a message appears above the Coder to explain the error. A red light means the project can’t run, either because slot 1 is empty or because the cards are in an order that can’t run.
Screen Reader
Another important accessibility feature in the Digital Coder is its screen reader compatibility. With the device's screen reader turned on, cards are read aloud so those with visual impairments can easily understand which Coder cards are being used in a project.
Turn on your device's screen reader in its accessibility settings, then turn on Accessibility mode. The cards are read aloud.
Place Cards by Dragging or Tapping
Cards can be placed in more than one way, with or without Accessibility mode. This ensures students have multiple ways of physically interacting with the Coder.
Drag a Card
Drag a card from the toolbox into a slot. The slot is highlighted when the card is over it. Let go to place the card.
Tap a Card
Tap a card in the toolbox to select it. The selected card is outlined.
The empty slots are outlined to show where the card can go. Tap the slot where you want the card.
To learn how to build, run, and step through projects with the app, see Using the VEX Digital Coder.
