The VEX Digital Coder is an app version of the physical VEX Coder included in a VEX 123 Kit. The VEX Digital Coder enables students to use Coder cards to code a VEX 123 Robot or a VEX GO robot. Students build projects by placing Coder cards in the app, then run them on a VEX 123 Robot or a VEX GO robot over Bluetooth.
The steps and screenshots in this article show the VEX Digital Coder on a tablet with VEX 123, and the same steps work for VEX GO. Any differences for VEX GO are noted where they apply.
The web-browser version of the VEX Digital Coder is available at coder.vex.com. In addition, the app is available for iOS, Android, and Amazon Fire devices.
The Android and Amazon Fire apps are available now on Google Play and the Amazon Appstore. The apps for iPad and iPhone are pending approval on the App Store.
Choose a Platform
Select 123 or GO at the top of the app to match your robot.
The toolbox changes to show the Coder cards for that platform. Each platform keeps its own project, so switching does not clear the other one.
Connect a Robot
Select Connect robot.
A window opens and starts looking for robots nearby. On Android and Amazon Fire devices, the device's own list of nearby devices opens instead, so select your robot there.
To check which robot is which, select Locate next to a robot's name.
The robot will play a sound effect and/or flash a light.
Select the name of your robot.
Robots are listed by name, with their battery level.
Once the robot is connected, its name appears at the top of the app.
If the robot needs a firmware update, the update starts on its own. Keep the app open and the robot nearby until it finishes.
Select the robot's name to open the Your robot window.
This window shows the type of robot, its battery level, and its firmware version.
Select Disconnect to disconnect the robot from the app.
Build a Project
Every project begins with the When start 123 card in the top slot. In VEX GO, this card is When start GO.
The start card can't be moved or removed. Add up to 10 cards in the numbered slots below it. The project runs from top to bottom.
You can also tap a card in the toolbox to select it.
The selected card is outlined.
Then tap the slot where you want the card.
The empty slots are outlined to show where the card can go.
To move a card, drag it to another slot, or tap it and then tap the new slot.
If the new slot already has a card, the two cards swap places. Dragging a card from the toolbox onto a filled slot replaces the card in that slot.
To delete a card, tap it and select Remove.
You can also drag the card back to the toolbox.
To delete the whole project, select the trash can.
Every card except the start card is removed, and the trash can turns into an undo arrow that puts them back. The app does not save projects, so when you close and reopen the app, the Coder starts with only the start card.
Start and Stop a Project
Select Start to start the project on the robot.
The lights beside the cards flash green in order as the app reads the project, then the robot begins.
As each card runs, the light beside it glows green.
This shows which card the robot is carrying out.
Select Stop to stop the project at any time.
If a light turns red, the project can't run until that card or slot is fixed.
A red light means there's no project to run, for example because slot 1 is empty, or that the project's logic is incorrect, such as cards in an order that can't run.
Turn on Accessibility mode to see a message that explains what to fix.
Step Through a Project
Select Step to run the project one card at a time.
Stepping lets you see what the robot does at each card, which helps you find and fix mistakes.
A yellow light shows the card that will run the next time you select Step.
When you first select Step, the yellow light is next to the start card.
Select Step again to run the card with the yellow light.
Its light turns green while the card runs, then the next card’s light turns yellow. Keep selecting Step to run each card in order.
To learn more about debugging with Step, see Stepping Through a Project with the Coder.
Use Accessibility Mode
Select the Settings button.
Select Accessibility mode to turn it on.
Lights show a symbol as well as a color, cards use darker colors that are easier to read, and a message explains any error in the project. If the device’s screen reader is on, cards are also read aloud.
With Accessibility mode on, each light shows a symbol as well as a color.
A check appears on green lights, ! on yellow lights, and × on red lights, so you don't have to rely on color alone.
Error messages appear above the Coder to explain what needs to be fixed.
Here, slot 1 is empty, so the message says to add a card after When start 123. Select × to close the message.
To learn more about the app's accessibility features, see Accessibility Features in the VEX Digital Coder App.
Change the Language
Select the language menu at the top of the app to choose a language.
The cards, buttons, and messages change to that language. You can also change the language in Settings.
Use the App on a Phone
On a phone held vertically, pull up the Cards panel at the bottom of the screen to show the cards.
Drag or tap cards from the panel into the Coder, just like on a tablet.
Pull the Cards panel back down to see all 10 slots.
On a phone held sideways, the cards appear in a sidebar beside the Coder, as they do on a tablet.
Scroll the Coder up and down to see all 10 slots.
For more information about the physical Coder, see Using the VEX Coder.
