Get Started with a VEX IQ (2nd gen) Classroom Bundle
When you get your VEX IQ (2nd gen) Classroom Bundle, there are a few things you can do to get yourself organized and started. This article will cover the basics of unpacking your Classroom Bundle and getting ready to use VEX IQ (2nd gen) with your students.
Product image for the VEX IQ Classroom Bundle with its contents shown and labeled. The contents include IQ Education Kits (Motion Bin), Carrying Case for Fields Walls and Objects, IQ Education Kits (Structure Bin), STEM Game Objects, Spare Parts with Storage, Extra Pin Tools, Extra USB-C Cables, Classroom Chargers (5 USB-C Ports), Parts Poster, and finally STEM Games Field Tiles and Walls.
Note: All of the resources in this article are based on a Small Classroom Bundle. If you ordered a Classroom Bundle, you will receive the equivalent of two Small Classroom Bundles. If you ordered a Large Classroom Bundle, you will receive the equivalent of three Small Classroom Bundles.
This article reviews all of the pieces in your VEX IQ Small Classroom Bundle and where you can find them. For an in-depth view of everything in the Small Classroom Bundle, watch the unboxing video below!
  • Part: This is the name of the part.
  • Photo: This is an image of the part. Use this for reference while unboxing your Classroom Bundle.
  • Quantity: This is the quantity of each part provided.
  • Location: This is where you can find the parts in your Classroom Bundle.
  • Helpful Hints: These are provided in the Location column. These hints provide extra context or information on packaging, identifying part numbers, or tips for additional organization.
Part Photo Quantity Location
IQ Education Kits - Structure Bin VEX IQ Education Kit - Structure Bin. 5
Helpful Hint:
Label each bin so that the Structure bin and the Motion bin remain paired together as you distribute kits in the classroom.
IQ Education Kits - Motion Bin VEX IQ Education Kit - Motion Bin. 5
Helpful Hint:
Field Tiles VEX IQ Field Tile piece. 12 These will be located in the blue Carrying Case.
Field Walls VEX IQ Field Wall piece. 16 These will be located in the blue Carrying Case.
IQ Cubes 3 VEX IQ Cubes shown. One cube is red, one is green, and one is blue. 18
Helpful Hint:
You will receive 6 IQ Cubes of each color: red, green and blue.
Parts Poster Page 1 of the 2nd gen VEX IQ Classroom Bundle Parts Poster.Page 2 of the 2nd gen VEX IQ Classroom Bundle Parts Poster. 1
Helpful Hint:
The PDF version for the Parts Poster can be found at posters.vex.com.
Extra USB Cables 5 USB Cables for use with VEX IQ (2nd gen). 5
These will be located in the blue Carrying Case. Remember to check the zipper pockets while unpacking the case.
Helpful Hint:
Keep the extra USB cables with the Classroom Chargers so the USB cables in the Electronics Bin can be used for connecting to VEXcode IQ.
Classroom Chargers 2 Classroom Chargers are shown, the larger one has 4 USB ports and the smaller one only has 1 USB port. 2
Helpful Hint:
There are 5 USB ports between the two chargers, so you can charge 5 IQ Brains or 5 IQ Controllers with one outlet. Keep the extra USB cables with the Classroom Charger so the USB cables in the Electronics Bin can be used for connecting to VEXcode IQ.
Extra 1 x 1 Connector Pins
Jewel Case with Extra 1 x 1 Connector Pins. 1 Jewel Case with 221 Connector Pins
All extra jewel cases will be located in the blue Carrying Case on top of the IQ Cubes.
Helpful Hint:
Each set of extra parts will be contained in a small jewel case. Remove these and keep them in a teacher-only area to ensure your extra parts are not mixed into existing IQ Kits.
Extra Connector Pins and Cable Anchors Jewel Case with Extra Connector Pins and Cable Anchors.
1 Jewel Case with
  • 53 1 x 2 Connector Pins
  • 21 2 x 2 Connector Pins
  • 22 0 x 2 Connector Pins
  • 21 0 x 3 Connector Pins
  • 11 Cable Anchors
Helpful Hint:
Extra Chain Assemblies and Links, Traction links, Intake Flaps, 24X Pitch Ropes, Rubber Bands and Center Lock Beams Jewel Case with Extra Chain Assemblies and Links, Traction Links, Intake Flaps, 24X Pitch Ropes, Rubber Bands, and Center Lock Beams.
1 Jewel Case with
  • 2 Chain Assemblies
  • 5 Chain Links
  • 5 Traction Links
  • 3 Short Intake Flaps
  • 2 Medium Intake Flaps
  • 2 24x Pitch Ropes
  • 2 Rubber Bands
  • 2 1 x 3 Center Lock Beams
Helpful Hint:
Extra Standoffs, Standoff Extenders and Standoff Connectors Jewel Case with Extra Standoffs, Standoff Extenders, and Standoff Connectors.
1 Jewel Case with
  • 11 0.25x Pitch Standoffs
  • 13 0.5x Pitch Standoffs
  • 13 1x Pitch Standoffs
  • 15 2x Pitch Standoffs
  • 5 4x Pitch Standoffs
  • 6 6x Pitch Standoffs
  • 11 0.5x Pitch Standoff Extenders
  • 13 Mini Standoff Connectors
  • 9 End Standoff Connectors
  • 9 90 Degree Standoff Connectors
Helpful Hint:
Extra Shafts, Idler Pins, Washers, Spacers, Rubber Shaft Collars, 1 x 1 Beams, 12 Tooth Gears, 8 Tooth Sprockets, 1 x 4 End Lock Beams Jewel Case with Extra Shafts, Idler Pins, Washers, Spacers, Rubber Shaft Collars, 1 x 1 Beams, 12 Tooth Gears, 8 Tooth Sprockets, and 1 x 4 End Lock Beams.
1 Jewel Case
Helpful Hint:
Carrying Case for Field Tiles, Walls, and Game Elements VEX IQ Carrying Case for Field Tiles, Walls, and Game Elements. 1 This Carrying Case will contain all of the extra parts, cables and chargers, the parts poster, the Field Tiles and Walls, and the game elements of your IQ Classroom Bundle.
