Using VEX IQ (1st generation)? See this article.
Many VEX IQ products contain their own internal processors and run on a special Operating System. This software is the VEX IQ Firmware and is called VEXos.
Note: VEXcode IQ can only update the firmware on the IQ (2nd generation) Brain when connected to a device via a USB cable. VEXcode IQ does not support updating the firmware on the IQ Brain when using an iPad, Android, or Fire tablet.
What is Firmware?
This Operating System is written entirely by VEX Robotics, and harnesses the flexibility and power of VEX hardware for the diverse needs of education and the rigors of competition. The Brain will automatically push out the latest updates to any IQ device that is connected to it.
Why Should I Update?
There are several reasons why you should update your VEX IQ Controller and Brain’s firmware with the latest VEXos, some of these include:
- Each update of VEXcode IQ will require the latest version of the VEXos firmware installed on the Brain before user programs can be downloaded.
- VEXos updates will include fixes for known bugs and add the software which is needed to operate any new devices introduced into the VEX IQ line.
- Updates allow for advanced programming features.
- The best way to ensure that your VEX IQ system is functioning properly is to keep the software up to date.
How to Update (2nd generation) Brain Firmware
Make sure the Brain is properly wired to your computer and powered on.
Once the Brain is connected, launch VEXcode IQ.
Note: if you do not have VEXcode IQ downloaded, visit this page to download it.
If the Brain icon color on the VEXcode IQ menu bar is orange, you will need to update your firmware. You can update the Brain in VEXcode IQ by selecting the ‘Update’ button.
Wait while the firmware updates.
Once completed, select ‘OK.’ The IQ Brain will power off and then back on, known as power cycling.
Once your firmware has been updated, the Brain icon will turn green.
How to Update (2nd generation) Controller Firmware
Before beginning, ensure that your Controller and Brain are paired. See this article for information on how to wirelessly pair a (2nd generation) Controller and (2nd generation) Brain.
Using a USB-C cable, connect your Controller to your computer and ensure it is powered on.
Once the Controller is connected, launch VEXcode IQ.
If the Controller icon color on the VEXcode IQ menu bar is orange, you will need to update your firmware. You can update the Controller in VEXcode IQ by selecting the ‘Update’ button.
Once your firmware has been updated, the Controller icon will turn green. If already paired with a Brain, the Brain icon will also turn green.
Note: If your Controller is not paired to a Brain, the icon will remain orange.
